Question about Creative Labs Audio Players & Recorders
Humm sound from of creative 2.1 inspire t3030 main speaker
Creative inspire 6100 no sound just humm
try replacing the audio output cable that feeds the speakers. the computer reads it plugged in by breaking the circuit when its empty. check the entire length of the cord for cuts and breaks, and check the plug ends. best test is using a multimeter and checking each section of the plugs for continuity.
Dec 16, 2014 | Creative Labs Inspire T6100 Computer...
Hi. where can I download creative inspire t3030 driver for mac?\ Tnx.
Surprisingly, drivers aren't actually required for that model!
Aug 20, 2011 | Audio Players & Recorders
Ok, so I have had creative inspire T3030 2.1 speakers for more than a year now, but recently I noticed slight cracking and popping sound coming out of the left satellite speaker. I tried swapping them and...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 12, 2011 | Creative Labs Inspire T3030 Computer...
I use the system in my room for my i pod and one day it just stopped working. when i plug it in and try to turn it on, nothing happens and there is no green light...whats wrong?
This sounds like the power adapter for your speakers is not working.
If you have some electronics experience you can test your adapter with a multimeter or maybe have someone else do it for you.
If you plan to replace the adapter, (if it is the adapter that is not working) be sure to use the same AMP and Voltage rating that is on the original.
Nov 29, 2010 | Creative Labs Inspire T3030 Computer...
How do i set up
Ty this - there is one wire with a green end - plug this into the sound card on your pc.
Take the one wire from the left speaker and plug it into the main control box to the matching plug.
Take the remaining wire and plug it into the other matching plug on the back of the main LARGER control box.
Plug it in the wall socket.
Play music on your pc.
Mar 29, 2010 | Creative Labs Inspire T3030 Computer...
No sound from creative t3030 2.1 speakers
you checked adapter light the green light is show
Jul 23, 2009 | Creative Labs Inspire T3030 Computer...
Speakers work with ipod not with laptop
ok you need to plug the speakers into the green jack it is the speaker output jack
Apr 13, 2009 | Creative Labs Inspire T3030 Computer...
Creative Inspire T3030 speakers not working
hello
I have creative inspire T3030 ,dont function ,Iwant help
Mar 31, 2009 | Creative Labs Inspire T3030 Computer...
46 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
