Question about Mtd Garden
Remove pivot axle from mtd riding mower
I need to replace pivot bar on mtd riding mower. Can you help me?
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 147 Answers
SOURCE: I need help to replace
We need more information before we can advise. But maybe this can be a start. If this dose not help please contact me with more information about your product. Thank you.
Try this link. http://manuals.mtdproducts.com/mtd/Public.do
Posted on Jul 06, 2011
  • 6468 Answers
SOURCE: how to replace pivot arm bushings on mtd riding mower
most do not have bushings i use door hinge bushings from a auto parts store and drill out the arm to fit a bushing that fits the link
Posted on Oct 02, 2012
I have a 2 yr old MTD model series 790 riding mower and hard to turn.
First lift up the front tires of the ground with a jack. Look for a bent linkage bar or other damage or maybe foreign material that restricts the free movement of the linkage. Also check the front ball joints, axles and kingpins for lack of lubricant.
May 16, 2017 | Mtd Garden
Why can't I get wheel and rim off axle after removing pin?
Linda, you may have to spray penetrate oil on both ends of axle where it goes through the rim, spray a couple times, and then leave sit over night. The next day the oil may have worked its way in, you may still have to use a heavy hammer and board to get the rim off.(board to help from causing damage to rim).
Put the board over the rim and tire and give it a few sharp blows to get it moving off the axle. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HOW TO Remove Seized Lawn Tractor Wheel
How To Remove Wheel from MTD Riding Mower
Remove Lawn Tractor Wheel Without Damaging Cap
Apr 20, 2016 | Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How to replace pivot arm bushings on mtd riding mower
Sep 24, 2012 | Mtd Garden
MTD axle out replace
If the axle came out it will have poped the circlip off inside the box, simple enought to put back on, unfortunatly theres the time to get the box out and strip.
Jul 29, 2012 | Mtd Garden
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
Do you need a puller to remove tire off a yardman riding mower?
If you have successfully removed the wheel, You should be able to remove the tire, from the wheel, simply with a flat headed bar, or two.
Deflate the tire, then apply pressure, to break the bead.
Then insert the first bar to lever the tire over the edge.
Carefully repeat the process, and there you go.
Happy mowering:)
Jul 24, 2009 | Mtd Garden
Jun 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
How to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
May 15, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
MTD Riding Lawnmower
Sounds like the axle slipped out of the differential. There is usually a snap ring on the axle which holds it in place. This could have broken, came loose, etc,
Major surgery needed.
May 09, 2009 | Mtd Garden
Garden Logo
54 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
