Question about Opera Optics
Opera tv lvt-15cb03 turns on just a few seconds and then shuts down, how to reset?
DrGreeley
  • 3 Answers
SOURCE: mitsubishi WD-65731
Here is a link to what models have a recall for a faulty sensor... extended warranty on that part preplaceable for free by MDEA.
http://www.mitsubishi-tv.com/j/i/18312/Warranties.html?mid=125121
Posted on Dec 27, 2007
bobotfel
  • 236 Answers
SOURCE: LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: tv goes off once i turn power on.
I had the same problem with mine. One of the two fans were out on mine. I replaced the $9.00 fan, no problems after that. I fixed it myself after taking it to a Toshiba authorized repair facility, they said it was junk, can't get parts. They said buy a LCD. They never even took the back off of the set. Forty bucks down the drain for nothing. Nine dollar fan was all it was.
Posted on May 31, 2009
  • 36 Answers
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Posted on Jul 24, 2009
Hitachi-mex
  • 26 Answers
SOURCE: Receiver turns for a fews seconds then shuts down
Hi.
If the word "OVERLOAD" is in your display, we have a bad channel.
But if only turn off, and the standby led is on all the time, you need change a couple of resistor of 10 Ohms at 2 Watts in main board. But you need disassamble a must all the amplifier. A lot of work, but cheap part.
Best regards.
Posted on Oct 23, 2009
Anyone know how to fix a Panasonic Viera 50" Plasma that powers off a couple seconds after powering on?
tThe diagnostic circuits is shutting your TV down. In most cases the set will shut it down immediately. Apparently your set hasn't shut completely down yet. When you turn your TV on the diagnostic circuits send a low voltage, low frequency signal through all the circuits and depending on how they come back whether the sets powers up to full power. If a problem is detected it will shut down to protect the other circuits. It sounds like you might have some capacitors going bad on your power board. A capacitor that is going bad would let it come on for a few seconds then the diagnostic circuits would see the capacitor getting further out of tolerance and shut the set down. If you are a DYS type person you might want to lay it flat of it;s face and remove the back. A bad capacitor will be bulged out on the top. are Replace capacitors with the exact uf value and if you can go above the rated voltage but never below., If this isn't the problem then it is probably the main board (the board where your cable hooks up to), There are other things that cab causes for this but I would check the capacitors first.
Col. Dana Gillespie
Sep 09, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung UN46ES6500FXZA turns off by itself
I can not acces my Facebook deos not recognize or mail or password,how I can restart t.v to install and to atarte again please help me , thank you
Feb 10, 2014 | Samsung UN46ES6500 - 46" 3D LED-backlit...
Sharp LC-32D43U LCD TV doesn't turn on after a shut off but will after reset.
This is a typical memory problem. Better refer it to a qualified service technician.
Jul 19, 2012 | Televison & Video
How do i reboot my LC-46D64U
Do you mean a reset to the factory default settings? To reset, turn on the TV, choose Menu > Setup > Reset. Enter your code if you have a password on the TV. Select Yes and then Enter (the TV will shut off and then turn back on). You can't clear the secret number/password if you do not have it (write it down).
Other reboots - try turning off the TV and unplugging it for a few seconds. (If the firmware was being updated and the power went off, I do not know of any resets for the problem. I don't see anything about rolling back to previous firmware.)
I hope this helps.
Sep 18, 2010 | Televison & Video
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When turned on, my Mitsubishi TV shuts off after a few seconds.
the lamp is simple; yet you can run into problems with this tv. be very careful replacing lamp. the plug in the tv can be damaged. (due to the design)
lamp part #
915P028010
Mar 13, 2009 | Mitsubishi WD-62526 Projection TV
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Tv wont turn on
sounds like you're right on the front of a control board failure..how tech friendly are you?
Mar 15, 2008 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Panasonic pt-61lcx65
I have the same TV and just replaced the same lampTY-LA1000.
You have to reset the clock that times the lamp.Hold down the volume button(first you turn on the TV) while holding down the PiP button or the swap Button on the remote. that fixed mine.
Jan 11, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
TV shuts off automatically
I Can Assure You That This Problem Is Associated With 2 Capicators On The Power Supply Board.
Aug 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Optics Logo
56 people viewed this question
Top Opera Optics Experts
james laughton
james laughton
ray gallant
Are you an Opera Optic Expert? Answer questions, earn points and help others
