Question about Sharp Mx-m450n Mfp Multifunction Booklet Maker M450n M450 Copy/print/scan/fax
Error code U6-02
Sharp MX-M450N copier getting Error code U6-02
    Scholar:
  • Sharp Expert
  • 120 Answers
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Posted on Apr 22, 2014
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
SOURCE: Get an user manual for a sharp copier model #AR-M450N
sharp.com should have the manual to down load
Posted on Dec 16, 2008
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Posted on Apr 20, 2009
Cogz
  • 1326 Answers
SOURCE: how do you replace the drum in Sharp AR M450N copier?
Basicly, any screws that are Blue in color can be removed. It is very easy to do if you know how Sharps are... You may be getting your self above your head... You also, have to reset the drum counter & drum cycle counters... Good Luck
Posted on Jun 12, 2009
hamzaskilltd
  • 316 Answers
SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
Posted on Jun 06, 2010
Sharp mx 350n code e7 90
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 29, 2014 | Sharp AR-M450N Black & White Copier
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Dec 28, 2009 | Office Equipment & Supplies
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of...
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Jun 17, 2009 | Sharp Office Equipment & Supplies
Dec 03, 2008 | Sharp AR-M450N Copier
Sharp Mx-m450n Mfp Multifunction Booklet Maker M450n M450 Copy/print/scan/fax Logo
368 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
