Question about Lincoln Electric Vantage 300 Kubota One-Pak Engine Driven Welder
Output nonr? Never welded with it yet started once has no output
Ranger 10,000 has low weld output and ac output
This is not a simple question. Take this magnificent machine to a service shop.
Aug 25, 2014 | Lincoln Electric Ranger 250 GXT AC/DC Arc...
If I turn the ac dc switch while what dose it do to the wielder. Now im not getting any juice to wield .thank you
Changes between AC and DC voltage at the electrodes.
Q: What Type Of Stick Welder Works Best For All-Around Use?
A: A welder with an AC/DC output, whether its an electric arc machine like Miller\'s Thunderbolt or a gas engine drive like Miller\'s Bobcat.
DC welding offers advantages over AC for most Stick applications, including: easier starts; fewer arc outages and sticking; less spatter/better looking welds; easier vertical up and overhead welding; easier to learn "how to weld" and a smoother arc. DC reverse polarity (electrode positive) provides about 10 percent more penetration at a given amperage than AC, while DC straight polarity (electrode negative) welds thinner metals better.
Q: Does An AC Output Have Any Advantages?
A: Yes, if you need to weld on material that\'s become magnetized from friction, such as when hay, feed or water constantly rub against a steel part. A DC output won\'t work because of "arc blow," where the magnetic field blows the molten filler metal out of the weld puddle. Because an AC output alternates between polarities, it enables you to weld magnetized parts.
Aug 19, 2014 | Computers & Internet
Miller 280nt trailblazer has AC power but no weld output? already checked the f1 and f2 fuse
Sounds like an internal problem. You will probably have to take the casing of the welder off and examine all your wire sets. It could be something simple as a connection issue. The transformer may have blown as well.
Jun 03, 2014 | Miller Welding Tools
Amp gtp500
Check output transistors
Jun 16, 2013 | Adcom GFA-5400 2-Channel Amplifier
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No or little ac output
By ac you mean receptacles, not ac welding?
If so what about welding output on AC (DC)?
If welding is OK then you may have breaker or fuse problem.
If welding output is also low or no output your problem is the generator.
You should check your gen rpm to be normal. If so you may have field problem: rectifier, AVR etc.
If you can measure the field DC voltage at rated rpm, if it is missing (very low) try to find any circuit broken.
If you do not succeed answer this instruction in order to give you more.
Jul 20, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
Will not weld or arc , I bought my ranger after hurricane ke ask a generator, and never elded with it. today for the first time I tried to weld with it and it will not arc
Make sure the WELD TERMINALS SWITCH is in correct position.: In the WELD TERMINALS
ON position, the output is electrically hot all the time.
In the REMOTELY CONTROLLED position, the output is
controlled by a wire feeder or amptrol device, and is electrically
off until a remote switch is depressed. If you don't have your manual, you can download one at http://www.mylincolnelectric.com/Catalog/operatorsmanualdatasheet.aspx?p=104081
Jul 18, 2010 | Lincoln Electric Ranger 305D K1727-2...
My lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Jul 03, 2010 | Lincoln Welding Tools
Lincoln Electric Vantage 300 Kubota One-Pak Engine Driven Welder Logo
15 people viewed this question
Top Lincoln Electric Electrical Supplies Experts
Steve
Gene Haynes
Are you a Lincoln Electric Electrical Supply Expert? Answer questions, earn points and help others
