Question about Venta Airwasher VS 207 3.7 Gallon Humidifier
Venta sonic humidifier blinking display - Venta Airwasher VS 207 3.7 Gallon Humidifier
  • 123 Answers
SOURCE: Venta humidifier manual
http://www.venta-airwasher.com/html/pdfs/User%20Manual%20AW%2010%20final%2027%20Mar%2006%20venta_AWguide.pdf
That is the link for your manual.
You can print it if you want.
Good Luck.
Posted on Apr 18, 2008
SOURCE: venta 207 digital humidifier
product will not turn on at all. I tried different outlets and put in a new filter, but still nothing. I also cleaned everything again. where can I take it to get it fixed/
Posted on Oct 31, 2008
SOURCE: Venta-sonic VS 207 humidifier. Turns on but the
I had the same problem. During the cleaning process, the white float was installed upside down and humidifier water level sensor was unable to read the float. I removed the phillips screw and inverted the float with the dark ring toward the bottm. Quick fix.
Posted on Dec 14, 2009
walesarumi
  • 6993 Answers
SOURCE: Venta-sonic VS207.... starting after summer
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting/no vapor in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils.
If, after adjusting the settings and cleaning the unit, you still don't see no vapor/water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Posted on Oct 20, 2010
  • 11 Answers
SOURCE: How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Posted on Dec 28, 2010
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
Fill Water Tank.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
The humidifier will not turn on ---only a faint blinking light when I push the power button or the other buttons---no humidified air is coming out no matter what I press/
http://www.airkinglimited.com/airking/admin/article_instructions/5000IO.pdf
Here's a link to the install manual.
Check out the section on setting the dip switches, it may help.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 27, 2010 | Venta - Airwasher LW44 Humidifier
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all summer (followed the manual instructions) and it's the first time I'm turning it on.
Nov 08, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta humidifier is not humidifying much.
Buy a new filter cartridge. www.ventahumidifiers.com
Mar 16, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Jan 30, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Venta 207 digital humidifier
Caring For Your Venta-Sonic Humidifier
IMPORTANT!
Always unplug the unit before cleaning!
When to Clean Your Humidifier
 Clean your humidifier weekly or more often during heavy use, depending on your
individual water quality. Clean your humidifier before storing and after long periods
of storage.
 When cleaning the inside of your unit, keep water away from the air outlet. Exterior
may be wiped with a damp cloth when unit is off and unplugged.
Cleaning the Oscillator and Water Sensor
 Turn off the unit and unplug power cord. Remove tank from base and empty
reservoir in base. Use cleaning brush provided in base to clean off mineral deposits
and sediment from oscillator and water sensor. Do not scrape or clean with tools
that have metal parts. Be careful to not damage the surface of the oscillator.
ATTENTION: Damage to the oscillator may cause the unit to not work properly.
 The oscillator (ultrasonic transducer) is highly sensitive. Keep this important part
clean and treat gently. Do not touch the oscillator while the unit is operating.
 Do not use soap, cleaning agents, detergents, or other chemicals for cleaning the
tank and humidifier.
 After cleaning fill water tank (see instructions above) and return tank to base.
Storing the Venta-Sonic
Switch off and unplug power cord from A/C outlet. Empty remaining water from base
and tank. Clean tank and unit (see for instructions above). Make sure all parts are
thoroughly dry—allow at least 24 hours to dry. Leave the filling cap of the tank
loosened. This will keep the cap and gasket from sticking together. Pack Venta-Sonic
in original packaging and store in a cool and dry place.
You can find your manual at this link:
http://www.venta-sonic.com/pdf/vs207manual.pdf
Good Luck.
Apr 03, 2008 | Venta VS 100 Humidifier
Venta Airwasher VS 207 3.7 Gallon Humidifier Logo
172 people viewed this question
Top Venta Humidifiers Experts
Paul Carew
Dennis
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
