Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer keeps running after cycle is over
Whirlpool washer- will only run on normal cycle, and when the cycle is over, it doesn't stop, it starts to refill again
    Sergeant:
  • 212 Answers
Timer contacts inside of timer are not losing contact which in returns the timer thinks it has been told to continue cycle. replace timer. not hard to do but timer is around hundreded bucks.
Posted on Jul 02, 2009
It sounds like from what you have given me is that the timer could need replacing
Posted on Jun 26, 2009
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
My Whirlpool Washing Machine W10560167A restarts after completing a wash cycle. Is their any way to fix this problem or why it keeps restarting?
Need model # that is apart # or diagram number the unit is programmed for continous run provide model # will explain how to take out of this mode
Sep 25, 2014 | Whirlpool Washing Machines
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
During normal cycle agitation is a constant stop/start
Yes, the timer mechanism should be replaced asap. the timer has a motor that is responsible for the rotation of the device. This motor is damaged, in return, not allowing the normal cycle to initiate and transfer sequential information to the motor properly.
Replacing the timer will correct this issue.
Aug 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
Whirlpool duet post washer 2006 model will not start any cycle and only hums and pumps odl water out
Sounds like your pump is clogged....first you need to remove the front cover below the loading door... (will be 3 Phillips screws on the very bottom). You will see a white cap in the very center bottom. You are going to need a bowl to catch some water and probably some debris when you remove it....Make sure you get all the debris (coins wrappers...ect... I made about $2.75) out before you put the cap back on the drain...Then try to run a normal cycle again. You can always run the diagnostic program that is found in the manual which is also located behind that front bottom cover if the normal cycle doesn’t go all the way through.....then you got me.....the pump is probably out but you will get more information if you run the diagnostics.....Good Luck.....
Sep 21, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
234 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
