Question about Garden
Mountfield rotary 4 stroke grass cutter motor 'hunting' continuously.
Machine still cuts grass, but is difficult to start. Engine 'hunts' all the time.
  • Norman Price Apr 22, 2014
    Thanks for previous answers, but they do not fully address my problem.
    Add a CommentI have to prime the engine up to 20 pushes on the primer button, and when it does start the engine is continuously speeding up and slowing down again. I've called thos 'hunting', but there may be a more technical term for it. I've checked the line from the petrol tank to the carb. and it is ok
    Habit-Forming:
  • 78 Answers
Norman PRICE THE WORD HUNTINDG IS TRUE THE MOTOR IS LOOKING FOR FUEL ON SOME MOTORS YOU ADJUST THE MIX ON THE CARB CHECK THE AIR FILTER TO SEE IF PLUGED ON A FOAM FILTER YOU CAN CLEAN ON A PAPER YOU WILL NEED TO REPLACE. ANOTHER THING IS HOW OLD IS THE GAS . TODAY THE GAS IS ONLY GOOD FOR A MONTH,
Posted on Apr 26, 2014
  • Norman Price Apr 26, 2014
    Dennys2360. Many thanks for your answer. The air filter is foam and clean, but must admit the gas is about a year old. I didn't know that gas today degenerates so quickly..
3 Suggested Answers
SOURCE: Kia ora, i have a
Engines need 4 things: Spark, compression, fuel, exhaust
1) Does spark plug have spark?
Take out plug, put plug wire back on plug, hold plug threads against metal part of engine, pull cord, do you see spark between plug and engine?
2) While spark plug is out, put finger over hole and pull cord. Do you feel suction that shows compression?
3) What about the exhaust port? Is the screen blocked with carbon deposits and dirt? Soak it in WD-40.
4) Do you have 2-cycle oil in gasoline? Do you have fresh gas? Did you leave gasoline in tank for several months? Is the carburetor clogged with gum?
5) What about the air filter? Does it fire up without air filter? Will it fire if you spray WD-40 into carburetor? Can you keep it going while spraying WD-40 into carburetor?
If it fires with WD-40 but won't keep going on it's own, then the gas is not getting to carburetor or carburetor is clogged with gum.
Posted on Oct 08, 2010
SOURCE: May 4, 2011 I purchased
I have the same model purchased last spring from Home Depot. I finally learned to prime it 6 times instead of 3 like it says on the mower. After pushing the primer 6 times mine starts fine. It usually requires priming even when the engine is warm to get it to re-start unlike any mower I have had in the past.
Posted on Sep 17, 2011
Why does my Mountfield Petrol powered lawn mower cut off instead of idling while I empty grass cuttings?
what engine does it have, how old is it and does in not have a bar you have to hold in to start/stop the engine?
Mar 07, 2015 | Garden
Why does mower cut out when cutter blade selected?
this is posted is cell phone section. unless cell phones cut grass now this is a miracle. please change catagory and please add make and model of mower.
Apr 25, 2014 | Huawei Cell Phones
Water comes out of detergent port
detergent valve is ball bearing and spring. make sure its clean and the right way around and damage free.hunting can be caused by incorect idle, and is normal if machine is building up pressure when not being used.
Apr 05, 2014 | Annovi Reverberi Garden
HOW CAN A COMPANY LIKE MOUNTFIELD,FIT THIS **** CHINESE RS100 ENGINE,,NO MATTER WHAT YOU DO THE REVS HUNT,,ITS RUBBISH AND ONLY USED 6 TIMES
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Hunting is caused by a lean fuel condition in most engines, this can be intake leaks or a carb or fuel injection problem. We have little or no info on any Chinese products like this, they are sold and after that they don't real care..
Sep 07, 2012 | Cars & Trucks
I am looking for a Mountfield HP 470 Lawnmower instruction manual
I have a Mountfield HP 470 Petrol Mower 8 years old and I have started it the for the first time and it runs but seems to be hunting or missing as I cut the lawn.
Mar 24, 2011 | Garden
How do I change a worn Carburettor Gasket and Diaphram on a SP470 B&S Engine on my Mountfield Lawnmower? I'm good at DIY. The engine is hunting and running erratically.
Hunting and erratic operation are signs of air leaks or diminished fuel flow at WOT settings.
If this mower is running a vacu jet style carb with a diaphragm you simply take off the air cleaner, the vent tube, and then the four screws holding the carb on the gas tank and after the carb body can be lifted remove the throttle linkage so you can flip over the carb and pull the main jet and clean the inlet screens.
http://www.psep.biz/store/briggs_stratton_carburetor_kits.htm
Aug 11, 2010 | Briggs & Stratton Garden
Honda stationary engine hunting 5HP
The IAC, (Intake Air Control valve) is a rotary valve that binds with carbon build up. the valve is usually on the bottom of the throttle body, has two small coolant hoses going to it.
Apr 07, 2009 | 2001 Honda Accord
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Stalling & hunting idle
does throttle sensor check out correctly???
Jun 10, 2008 | 1995 Volkswagen GTI
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
