Question about Air Tools & Compressors
Cedarwood door traditionally prepared for paint has bubbles under the new paint . What should we do to fix this?
5 Suggested Answers
SOURCE: Bubbling paint Under the wter and ice despenser.
Hey! Ours did the same thing, they also sell small tube of appliance paint, it has a brush like finger nail polish...anyway I used very fine sand paper to clean up the area, and sanded the rust off that was under the bubbled paint, and then painted a thin layer of the paint..wait until dry and add another coat. I did this about 4 or 5 times and it looks great now! I bought the paint at Walmart next to the spray paints....
Posted on Sep 06, 2008
SOURCE: why is the paint bubbling inside microwave
The paint or inside in my microwave oven was bubbling up. I didn't think much of it until my husband came down with tongue cancer. He didn't smoke or drink. The only thing that was strange was the way my microwave was bubbling up inside. We were given very grim news, but in time and by swithcing hospitals, my husband is now ok and has been cancer free for 5 years. If ever my microwaves start blubbling up, I throw them out, it wasn't worth the health hazards.
Posted on Aug 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Posted on Sep 06, 2009
Testimonial: "Very helpful and quick response. My Dad passed and I need another source for knowledge............."
  • 543 Answers
SOURCE: CAN DOOR PILLAR PANELS BE REPLACED OR SOULD A GUY
those do not come off,youre gonna have to fix and paint
Posted on Oct 08, 2009
Testimonial: "Thanks for advise it was just what I thought."
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Paint bubbles on drywall
It's been almost 10 months since the question was posted so how does it look? Most bubbles appear under the drywall tape or could be from primer / paint being rolled over drywall dust. Tape bubbles don't go away. These need repaired by cutting out the bubbled tape and filling in with compound. Tape bubbles can be avoided by using a TapeBuddy taping tool. This tool applies compound directly to the tape so there are no dry spots under the tape. Hope this helps.
May 05, 2014 | Drywall
Paint bubbles on a silver cloud
Either bad paint, or rust is forming under the paint.
Sep 17, 2012 | 1961 Rolls Royce Silver
I have a Goodmans Microwave ME20W in perfect order except someone has misused it and the paint under the rotating plate is blistered causing the oven to crackle in use. There is also one small area of...
Yes they can be cleaned. prepared and painted with enamel paint.
The reason the paint comes off is usually due to condensation as the oven is left with the door closed after use.
Mar 14, 2011 | Microwave Ovens
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
On my 2005 Crossfire the paint is bubbling on the deployable spoiler. Is this covered under a corrosion warranty?
NO,but it is normal for the paint to bubble on some plastic trims due to their makeup/type of plastic.the corrosion warranty is not worth the paper you use in the toilet...."applicable only if the paint surface is not broken and rust has taken place under the surface of the paint layers"(how do you know if its rust without breaking the surface to see.........)
Aug 14, 2010 | 2005 Chrysler Crossfire
Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
Air Tools & Compressors Logo
22 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
