Question about Samsung SCX-6322DN All-In-One Laser Printer
Open heat error, cycle power - Samsung SCX-6322DN All-In-One Laser Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 167 Answers
Fuser bad
Posted on Oct 02, 2015
2 Suggested Answers
Aneesh AM
  • 56 Answers
SOURCE: led screen says open heat error cycle power
if the Fuser unit rubber are not burned , change the
Fuser unit Thermister....
Posted on Apr 24, 2010
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
How to cycle the power on a Samsung CP610ND?
Pull out the plug, wait five minutes, replace plug and switch on.
Jan 07, 2014 | Samsung CLP-610ND Color Network Laser...
Open heat error cycle power
This error is caused when too much heat is generated. Simply unplug from the mains power for about 30mins to 1hr should help resolve the issue.
If this helps please rate this response. Thank You for supporting the FixYa community
Regards GM
Apr 08, 2011 | Samsung SCX-6322DN All-In-One Laser...
Samsung ML3051N open heat error cycle power
check the fuser assy thermostate , if pressor roller melt then change the fuser assy
Feb 19, 2011 | Samsung ML-3051N Laser Printer
Led screen says open heat error cycle power
Apr 24, 2010 | Samsung ML-2855ND Laser Printer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Open heat error
From looking at the manual it looks as if you have a faulty thermistor. When warming up, it has to heat up to at least 60 degrees. If it stays lower then 60 degrees celsius for over 35 seconds and doesn't reach 60 within that time frame then that would cause the open heat error that is happening on your machine.
Feb 09, 2009 | Ricoh AficioSP 5100N Laser Printer
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung SCX-6322DN All-In-One Laser Printer Logo
49 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
