Question about Hammering
Baumr-ag demolition hammer
Need to find replacement handle for 530 demolition hammer
jmgldsmth
  • 1869 Answers
SOURCE: Need manual for Hitachi Demolition Hammer
http://www.hitachipowertools.com/product/files/concrete_masonry/demolition_hammer/H65_OM.pdf
Posted on May 28, 2009
darjr
  • 378 Answers
SOURCE: Makita demolition hammer stopped working - believed electrical pblm
you have to use an ohmmeter to check it, you must check the continuity of motor coil after the switch terminal if in this point you have the reading less than 200 ohms, try checking it before the switch but this time you have to switch it on. If you have the readings continue to check it from the Power Plug. Most cases the problem is only in Power cord .
Posted on Jun 01, 2009
  • 142 Answers
SOURCE: Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Posted on Jul 06, 2009
  • 1383 Answers
SOURCE: this demolition hammer will make the sound like is
Large hammers have an air driven piston (an air cushion betweem pistons) and an intermediate anvil that actually hammers on bit. If the cylinder and air cushion piston are dry there will not be enough suction/pressure between the driver piston and driven. Remove lower part of hammer and lube with electric hammer grease. Make sure that orings fit snuggly and the anvil is not jammed. Do not store hammer with the bit pointing up because the driven piston will slide down cylinder and hug driver piston. If the hammer was stored pointing up, turn hammer around and place in stand with nose down in a warm location so that the driver piston will drop into place. Good holidays
Posted on Dec 17, 2010
rowdy45176
  • 2176 Answers
SOURCE: dewalt demolition hammer stopped hammering.
could be a few problems, the striker could be stuck from debris or the ram might be hydraulically locked. they make a rebuild kit for this tool if you are mechanically inclined. I would suggest first going to their site and downloading a parts breakdown and there you will find what is involved and the parts listing. It is "dewaltservicenet.com" and on the left hand side type in your model number and then follow the links to download this. Let me know if you need more assistance.
Posted on Apr 23, 2011
I have a baumr ag pro. i need a cylinder base gasket. where do i get one from baumr sx72.thanks,steve..
Try www.chainsawspairs.com.au it looks to me there are not any UK suppliers. Good luck.
Jun 09, 2016 | Garden
Oil Pump & Worm gear drive for Baumr-ag SX 72 72cc Chainsaw
Cant find much on your machine as its an obscure make and model. This brings with it the ease of sourcing parts, sometimes its better to stick with known brands for this reason.
I managed to find this, it might be worth comparing it to the one on your machine. Hope it helps.
http://www.chainsawspares.com.au/oil-pump-and-worm-drive-for-baumr-ag-sx25-25cc-cha
Mar 30, 2016 | Garden
Baumr ag User Manual Needed
http://baumr-ag.com.au/where-buy-baumr-ag
  • There should if available for your model type a maintenance kit neccesary for your model or all the used o-rings and sometimes special tools because there are special buna-n or nbr o-rings used sometimes braun or green colored on some parts and gaskets, seals and rings used and allways if your tool is leaking then replace the impact bold in front of the spindle if you have find the right drawing for your model type
  • The right lubrication is very important in combination of the o-rings because of the heat building release by rotating and hammering and a leaking tool has oft made all o-rings hardenet because of the failed pneumatic working loose of lubrication dried out principal it becomes very dry internal on some places and much to hot .
Sep 05, 2014 | Drills
I need a service centre for my Baumr SX 72 chainsaw in the Geelong?
Try reading
http://www.productreview.com.au/r/baumr-ag-62cc-professional/549822.html
Where I have a bit of a problem is that this question about a chainsaw is headed 'Problem with Video Cameras'. Maybe Fixya's fault.
May 29, 2014 | Video Cameras
Need spare part for baumr-ag professional pole pruner saw
Need a new pull starter mechanism/kit for Baumr - AG PNHT 4500 Professional Pole Pruner Saw
Feb 05, 2013 | Garden
Makita wire come out
Hi dean
Do you mean a Mkaita 1304b? Is it just the main cable that has come out? in which case you can undo half of the handle and reconnect it to the switch.
May 25, 2012 | Makita Hm3104b 35lb Demolition Hammer +...
Hello... I've rented a Bosch 11318 Hammer drill and it did not come with a manual......could you please tell me how to insert the bit. thank you.
You should only need to push the bit in. If that does not work grasp the chuck and pull back towards the handle than insert the bit and release the chuck. You remove the bit by doing the same pulling the chuck back and taking the bit out
May 09, 2011 | Bosch 11318evs 11 Amp Sds Max Demolition...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Hammering Logo
74 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
