Question about RIM BlackBerry Bold Smartphone
ERROR MESSAGE ON NAVIGATOR RELEASE LIB 55
ERROR STARTING TN-RIM-VERSION mODULE ' RELEASE LlB55 ' NOT FOUND
THIS IS WHAT SHOWS UP WHEN I TRY TO USE NAVIGATOR ON BB BOLD ATT CANT FIX AND DONT KNOW WHAT IT IS, CAN ANYONE HELP??
Delete and Re-Install the application
Posted on Jan 31, 2011
2003 Cadillac deville trunk randomly opens on its own when sitting and not running occasionally what could be the cause.
Do you know anything about automotive electrical testing ? how to read a wiring diagram ? How to use a DVOM - digital volt ohm meter ? You can find a free wiring diagram here http://www.bbbind.com/free_tsb.html
The trunk release is controlled by an electronic control moduel .
Trunk Release Relay
Output Controls
The rear integration module grounds the trunk relay when commanded ON. The rear compartment should release.
This vehicle has a very complex body control system of three different computers
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
. Rear Integration Module (RIM)
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Luggage Compartment Description and Operation (General)
Rear Compartment Lid (trunk) release actuation is controlled by the following components.
• Rear Compartment Lid Release Relay
• Instrument Panel Module (IPM)
• Rear Integration Module (RIM)
• Valet Switch
• Rear Compartment Lid Release Switch
• Rear Compartment Lid Release Actuator
Battery voltage for the coil side of the trunk release relay is supplied through the Valet switch (with the valet switch in the OFF position) by the ALDL fuse located in the Underhood Fuse (Bussed) Block. Battery voltage for the switch side of the trunk release relay is supplied by the Body fuse located in the Rear Fuse (Bussed) Block. When the rear compartment lid release switch is momentarily pressed, it provides a ground circuit for the trunk release signal of the Instrument Panel Module (IPM). When the IPM senses that the switch has been activated, it sends a Serial Data Class 2 message to the Rear Integration Module (RIM). The RIM then provides a path to ground on the F/TNK DR REL relay control circuit. The trunk release relay is then energized, and battery voltage is applied through the switch side contacts of the trunk release relay to the rear compartment lid release actuator. The actuator is connected to ground through a ground splice pack located at the left rear corner of the rear compartment, near the left tail lamp connector.
Mar 01, 2017 | Cadillac DeVille Cars & Trucks
Where does the pink praking brake wire go on 2003 cadillac deville go
Where are you seeing this pink wire ? I'm looking at a wiring diagram and I see a pink wire at the (RIM) rear integration module . It goes to the park brake relay A ,control side . The RIM supply's a ground on that circuit energizing the park brake relay A . There is another park brake relay - B . Are you familiar with the RIM module .
The park brake system is a mechanical and electrical system which operates on the rear disc brakes. The system is activated by depressing a foot pedal lever assembly, which sets the rear brake caliper via cables. The park brake is released by shifting the vehicle out of park or activating the manual release.
Park Brake Release
The rear integration module (RIM) controls the operation of the electric release park brake. The RIM uses serial data messages to determine if the correct conditions exist to release the park brake. The park brake is released under the following conditions:
• The engine is ON.
• The gear shift lever is not in Park or Neutral.
• The park brake switch is closed.
When all of the above conditions exist, the RIM releases the park brake by simultaneously activating the 2 park brake solenoids. After 2 seconds, the RIM deactivates solenoid A. The RIM continues to activate solenoid B while the above conditions exist, which prevents the park brake from being set.
Dec 23, 2016 | Cadillac DeVille Cars & Trucks
AT&T Navigator
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Phone Provider for Hardware Support.
Jan 12, 2010 | RIM BlackBerry Bold Smartphone
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My computer keeps closing down my E-Bay & Paypal when I'm trying to pay for a purchase. I have checked the error log and this is what is displayed: Faulting application iexplore.exe, version...
your best bet is to copy and paste your error message into Google and search it. I've always found an explanation to error messages this way. Matt
Nov 03, 2008 | Computers & Internet
Open VxdHandle Open VxdHandle could not be located in kernel32.lib
Try uninstalling drivers then reboot and install drivers. The vxd prefix is a driver that is faulty
Aug 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
RIM BlackBerry Bold Smartphone Logo
854 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
