Question about Toys
BL71 backhoe volvo: when I shift into forward or reverse nothing happens. I have tried different gears and the f/r switch and the loader handle switches, any ideas?
  • 156 Answers
SOURCE: gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Posted on Apr 08, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
SOURCE: PEREGO GAUCHO 4.0 WON'T GO FORWARD
Believe it or not but it is the reverse switch not the forwards one that is your problem.
Posted on Jun 02, 2010
  • 156 Answers
SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Posted on Jul 08, 2010
adamfjeld
  • 1508 Answers
SOURCE: Gator 6x4 tranny problem
try posting the question in the forum for john deere gator and not the forum for the kids john deere gator
Posted on Jun 08, 2012
416 backhoe won't go in reverse, Where is reverse solenoid lodated
Early model 416's were mechanical linkage to the control spool. Later models added solenoids to shift forward and reverse. This has a block with solenoids on each end.
All models have a separate solenoid for neutralizer function control by the push button on the speed control shift lever and loader control lever.
They are different were as some used current through the push buttons for the disconnect neutralizer solenoid and later models use current through the push buttons to power the transmission shifter.
When a failure occurred in the neutralizer circuit or a push button stuck, early models only need to disconnect the push buttons to make the transmission work but, later models must have a jumper installed to bypass the push buttons and keep power to the transmission control lever.
Current models are all controlled by an ecm.
An easy test to see if the transmission solenoids (if you have them) is to place a screw driver tip on the end to see if it is magnetized when you place it in forward or reverse.
All models also have a front wheel drive solenoid but, it is located in different areas for different models.
Test the push buttons to see if you have one stuck. Then check the wiring to see if the circuit is the problem. If you have the electric shift control handle, check the fuse first, the inspect the wire and circuits. If this is controlled with an ecm, you can still check the shift control wiring but, to test the ecm, a service call to the dealer is needed. Some models did include a red light in the fuse panel area to indicate an active fault is in the ecm circuit.
Feb 02, 2018 | Cars & Trucks
Keeps going into neutral and pops back into gear when it feels like this is a backhoe
Hi Frank:
Hydrostatic drive?
Shifter 3 position - Forward Neutral Reverse - Lever?
Follow the linkage from the shift lever. Probably a worn part or broken spring.
Jul 01, 2015 | Garden
Jsb will go forward and back for few seconds and then dont want to go forward and back
there will be oil leak or malfunctioning in the front & reverse gear ratio..its better to get ir repaired by a Mechanic
Thanks for rating Good luck
Jan 18, 2011 | Jcb Bruder JCB Loader Backhoe
Volvo 2006 S60 refuses to move in reverse direction
your problem lies in the internal parts of your transmission which are the clutch linings, they are already worn out and starts to slide.
May 28, 2010 | 2002 Volvo S60
Toys Logo
106 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
