Question about U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste...
Thermister open- U Line 2075DWRRSS under the counter two drawer refrigrater
Refrigerator wont cool. Flashing Indicator light indicate Termister Open. How do I fix this issue, do i have to change the thermister and is it easy to change? This unit is approx 10 year old. There was a loose connection wire in the 4pin connector which is located in the back of the top drawer, I had to finally remove the 4pin connector and directly wire it. The loose connection may have damaged the thermister. How do I fix this open thermister problem now, should I call for repair or is it easy to fix this problem?
  • 884 Answers
Can you get hold of a thermistor?
Posted on Apr 22, 2014
4 Suggested Answers
  • 286 Answers
SOURCE: U-line CO 2075 refrigerator stopped working, only
OK I'm guessing you have a clear icemaker. Not a co2075. When you replace the board you MUST replace the thermistors that come with the board. The board and thermistors are calibrated together. What is your model number? A clear ice maker has thermistors inside tubes. Except for the one on your filter dryer. Lets start with the correct model.
Posted on Aug 21, 2009
  • 286 Answers
SOURCE: Open Thermistor on U-Line
It might be a bad thermistor. I would need the exact model number. It could be a open harness as well.
Posted on Aug 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: Uline 2075DWRRSS stopped working.
Sounds like you have found the source of your problem. Yes,tighten all wires and wrap them with a zip tie.
Posted on Aug 03, 2011
My refrigerator is leaking water on the floor from the left side of the refrigerator
It sounds like you may have a frozen drain line in your freezer. If you have water under the crisper drawers in the ref section this would be a good indicator. If this is the case you could unplug the unit and leave both doors open for 24 hours to let your drain line thaw out. Hope this helps.
MJ
Oct 07, 2012 | Whirlpool ET1FHTXM Top Freezer...
Door open alarm sounds and door open indicator blinks, but refrigerator door and freezer drawer are closed. Alarm stops when you press Alarm Off pad, but door indicator continues to blink until it times...
The switch which detects whether the door is open may be malfunctioning or the control unit to which the switch is connected is faulty. If there is only one switch it may be the same switch which puts the light on as you open the door.Does the light come on when the door is open? If so the switch if there is only one, is probably ok but the control unit is faulty.Look around the edge of the door frame for switches and check they are not stuck or damaged. I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Viking Professional VCBB363 Bottom Freezer...
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have an older Amana SRDE25TW which doesn?t freeze/cool properly
It was probably the faulty thermistor all the time.
Feb 26, 2017 | Amana Refrigerators
I have magic chef mini refrigrater freezer not freezing and getting water in tray under freezer part. what can I do?
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Magic Chef MCBR440 Compact Refrigerator
Apr 15, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Repalce harness from temperature control
You need to drill out the rivets on the bottom of the drawer then slide the stainless sleeve up and out. Then you need to remove the 2 rivets on the middle part inside the gasket. Once you drill them out the insulation goes downward to remove. Then you will see the excess for the harness. Replace the rivets with flat head screws.
Dec 07, 2008 | U-Line Echelon Series 2075DWRRSS...
U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste... Logo
176 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
