Question about Boating
Johnson 6hp model 6R710 need details
Bought this motor with 12 ft boat need to know how to check its ok
  • ray gallant Apr 23, 2014
    fix a small barrel for a test aut t run slow then possibly you can get by without .king the prop off band try it out . some require
    Problem Solver:
  • 10 Answers
Basic check for any outboard: check compression in each cylinder, should all be within 10% of the lowest reading. With an air gap spark tester check spark. Your 6 HP spark should jump a 3/8" gap, blue crisp spark is good, yellow weak. Check gear lube with the motor in a verticle position, prop end down, unscrew the drain plug at the bottom of the gear case. Let a couple of drops out. Should be clean gear oil. If old it might be black and have a strong odor. There should be no water or metal filings. If it is milky there is water mixed in with the oil. If all checks ok run the motor. It should run smooth, no knocking and the cylinder head should be about 120 degrees. That is uncomfortable to keep your finger on but not so hot you cannot touch it. If it is too hot or too cold it can cause problems if run. Too hot will cause problems very soon, too cold will cause problems over time by building up carbon in cylinders and causing piston rings to stick.
Hope this helps.
Posted on May 08, 2014
  • 11 Answers
SOURCE: tryng to drop gear box off 6hp johnson how to?
If you are talkinh about unhooking the shifting rod from the lower unit, it might be behind a small plat held on with 2 screws on the side of the motor towards the bottom (casing that the lower unit dropped out of) or look uo in the housing , you should see how it is connected, usually a small bolt
Posted on May 03, 2009
oldfishead
  • 155 Answers
SOURCE: Shifter jumps out of forward gear on 64 9 1/2 hp Johnson motor
sound like the shift fork, or fwd gear is damaged in the lower unit.....special tools are required for this repair .....if you got them cool, if not seek a shop for further assistance.......hope this helped...GL
Posted on Jul 06, 2009
Editor925
  • 285 Answers
SOURCE: oil mixture for a 70 hp Johnson boat motor?
If it is a 2-stroke motor than gas:oil ratio should be 50:1
Posted on Sep 04, 2009
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
  • 45441 Answers
SOURCE: i need to change a water pump on a johnson 6hp
unbolt lower unit and you will be right there . shift rods vary so check where it is and how to unhook.
Posted on Apr 25, 2010
How do you turn a 6hp boat motor to a 8hp motor on a Johnson 1993
cheapest way is to buy a bigger power head
you may achieve the desired power by boring and fitting bigger pistons but you will have to have a long talk with a dealer service center technician to see if that would be feasible to do
as the motor is quite long in the tooth, it may be a better to consider a late model or new unit as the advantages of the later technology will be beneficial in the long run
Feb 01, 2017 | Johnson Boating
I have a short shaft Johnson 6hp outboard, the Jon boat I mounted it on is too deep, and motor doesn't reach water. Is there a way to lower motor? A bracket to lower motor to reach water?
outboard motor manufacturers supply a long shaft leg for just this problem
Talk with your Johnson dealer and check used outboards on e bay
Lowering the whole motor may affect the boat and floatation aspects besides making it harder to steer and start
Apr 15, 2015 | Boating
I need a free manual for a 1979 Johnson Seahorse 6HP, model number 6R79E
LOL FREE is not to be there are many on the market. clymers has a pretty good one covering a lot of sized motors
Jan 06, 2014 | Boating
Free johnson manual
LOL noone gives free anymore have to buy aftermarket one
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
How to adjust timing on johnson 6hp outboard motor
look at a manuel i think it is automatic in the switch no manuei adjustment get it timming through the cd like some of the mercks
Nov 08, 2011 | Light Outboard Motor Boat Bass Fishing...
I need to change a water pump on a johnson 6hp outbord moater. modle no. 6R-70B
Mar 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Sep 16, 2009 | Boating
Boating Logo
148 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
