Question about Fiskars Pruning Stik Tree Pruner
How to restring fiskars power stroke pruner - Fiskars Pruning Stik Tree Pruner
Need to replace the short rope inside the pole of my fiskars powerstroke hand pruner tool so where can I find that?
go to a hard ware shop that sells cords and ropes and make it using the old one as a sample
May 08, 2016 | Garden
The 8 angle anvil pruner sku #836-7013 has a design flaw. It is not a saw; it is not a chainsaw; it has Is there a pruner like this with a better design?
I think this is one of those cutter blade type of trimmers , I do know you have to keep blades razor sharp to cut anything with them , as they do tend to go dull easy (by design) , id go with a pole pruner chain saw if your looking to replace it , but beware as pruner chain blades and chain saws are not interchangeable due to fact that pruner's are made to cut on both sides of bar , chainsaws only cut on down stroke hence have a much more aggressive chain rake , don't put a chain for this on a pruner saw you'll be putting your self at risk of injury
Oct 08, 2015 | Garden
How do I unlock stuck blades on Fiskars pole pruner?
Just undo the bolt in the centre of the jaws. Tree Pruners
Oct 04, 2015 | Garden
How to restring a husqvarna 224L
To remove the head to restring, push in the bumper cap/side tabs on the strimmer head, the top should then just pull off exposing the inner spool.
Jul 24, 2012 | Husqvarna Weed Trimmer 224 L 4-stroke Line...
The ******** the Fiskars Power-Stroke pole pruner has become slack and won't open and shut the pruner blades. Would appreciate your help. Thanks.
Hi, you need to clean the blades and dry them and spray some WD-40 on any thing metal spring, blades, nuts, bolts. They get a build up of tree sap from cutting, regular cleaning and coating them with oil will prolong the life of any metal tools, also when you clean them make sure they are closing all the way without gaps. You may need to adjust the blades by adjusting the screws, take your time and adjust slowly so you turn in the right direction continually checking the gap.
Aug 04, 2011 | Garden
Sawblade fortree pruner #7186392
Your Craftsman Tree Pruner is a 1993 model. Sears no longer sells the replacement blade. The pruner was made by Fiskars for Sears. Check out their replacement blade Fiskars # 9333.
Oct 03, 2009 | Craftsman Garden
Fiskars Pruning Stik Tree Pruner Logo
708 people viewed this question
Top Fiskars Garden Experts
Dennis Key
Dennis Key
john h
Are you a Fiskars Garden Expert? Answer questions, earn points and help others
