How to use a hartford series 80 wood heater?
Dont know how to adjust fan speed?
2 Suggested Answers
farfield
  • 462 Answers
SOURCE: Fan capacitator size for Saxon 500 wood heater
The size is generally on the case of the capicator and is writtten in mfd or a kind of ufd or uf (the U stands for micro) F and FD = farads. The voltage rating is important but not nearly as mich as MFD. The voltage rating is how much voltage the capicator can stand before becoming critical. This capicator is usually mounted on the exterior of the motor.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK.
Posted on Mar 03, 2009
Repair manual for model#5ILR56 series ceiling fan
What is the make/model of fan? I don't know that # fanman9952@aol.com
Sep 14, 2014 | Dryers
Brivis me20e fan speed adjustable?
all u do is turn the wall controller to the off position. then press the clock button then hold buttons 2 and 4 down at the same time. let it load for 10 sec then turn the knob all the way untill it sais 1500 that is max fan speed then push the off on button to exit it. dont adjust any other values in here tho just the first one
Apr 20, 2014 | Heating & Cooling
Baffle plate has fallen to pieces in my parents hartford 80 wood fire. ??? how do ifix it or where to go for replacement.
This is not anything new as the parts in fire places burn out & need to be replaced Check with a fire place retailer who sells that type for spears .
Jun 12, 2012 | Cars & Trucks
I have a haywood h series h 400 pool heater. Each night the the pool pump timer runs b/t 12-7am.. The heater was working fine. and pool temp is around 70-80.. However, lately the heater which is on when...
Allheaters run off of a thermostat just like the heat to your house. It will shut off once heated to the selected temperature. Turn up the temperature, and monitor it for a couple days.
Dec 28, 2010 | Hayward H-series Electronic Gas Pool...
Hi, I ahve a Rheem Classic Plus Series SUper Quiet 80 Unit and no air is blowing thru the vents but the inside/outside units kick on? can you help?
Is the inside fan running? If it is then check your air filter. If it isn't, turn off power to the inside unit and see if the fan turns freely by hand. Next check the capacitor for the indoor fan. Does the fan on this unit connect to a circuit board? Set the thermostat to make the air come on and check for power where the fast speed wire connects to the circuit board and neutral. If it's not there, the circuit board is probably bad. You can look at the back side of the board to see if any traces are burnt off. Let me know what you find.
Aug 13, 2010 | Heating & Cooling
Burner nozzle selection for Kerosene torpedo heater
Hello Teisco I would go with semi-solid style Spray pattern is not related to ignition.Universal is probably semi-sloid but stay away from that one.Spray pattern relates to running combustion noise,style can make all the differance.A.50 nozzle can&will clog easily ,replace it and dont touch/change anything else.See if thats it.Pump pressure should NOT have changed but is 100PSI.spark gap, stick near 3/8 or less.If it lights & sputters out dont change the gap .Is there water in the fuel?
Jul 26, 2010 | Heating & Cooling
BWM heater problems--display and switches working but no fan
your fan speed regulator located on your heater core box is bad if its just one or some of the speeds. if the fan does not work at all its either a bad connection to your fan speed regulator or the fan motor has quit. out
Jan 26, 2010 | 2000 BMW 3 Series
Leaks after a couple of weeks use
You may need to put a hartford loop in your plumbing between your chlorinator and the heater. The chloriene will back up in the line bad when the pump is off and corrode the exchanger. A hartford loop is simpley a loop than runs low then high above the top of the heater so it can trap gasses in the line and won't let them get back in the line. If all else fails you can use a floater. Be sure to check your PH also. Good luck.
May 30, 2009 | Hayward H Series Electronic Ignition...
Heater fan only works on high after replacement of heater core
It's very possible the fan motor has quit. The squealing noise is caused from motor bearing failure. As the bearings wear out or dry up the motor is harder to turn and require more current to run the motor. On lower speeds, the motor runs off a series of resistors that reduce the amount of voltage and current so the fan runs a lower speeds. If the bearings are worn, there is not enough voltage or current to turn the motor and that's probably the humming noise your hearing.
Good observation by the way.
Let me know.
regards,
Feb 13, 2009 | 2001 Chevrolet Prizm
HEATER BLOWER
faulty blower motor resistor
short behind climate button array
Dec 31, 2008 | 2001 BMW 5 Series
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
