Question about Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter
Drifts to the left. trim not fixing problem - Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter
Hercules unbreakable heli will not go straight up. As soon as it lifts off it starts drifting to the left. Is there a way fix?
you have to play with the trim in order the trim it to not go to that side so actually hit the trim towards where it's going and it should straighten that out of it
Jan 02, 2015 | Hercules Unbreakable Radio - controlled...
Hi I have purchased the Fxd flame strike r/c helicopter when I hover and try to move forward and backwards not much happens I have tried trimming the transmitter but with not much movement it just seems to...
Trimming is an adjustment used to get the helicopter to hover in place when you want it to hover in place (assuming no wind), not to adjust the gain (how fast it moves compared to control movement). If you don't have forward/back movement of the helicopter, there's a defect in there somewhere. If it's still under warranty, get it exchanged.
Sep 21, 2014 | Toys
Walking belt won't center and drifts to the left...sometimes seems to slip
http://www.youtube.com/watch?v=pStE-LlgIG4&feature=related
Please see this video for adjustment, you can see too another videos in the same web page from youtube.com such adjusting the deck belt,etc.
sincerely.Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 11, 2011 | Exercise & Fitness
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
2011 Lincoln MKZ 1500 miles 2 months old Car drifts to the left Dealer just replaced both control arms car still drifts left I dont think the dealer has a clue on what it could be
What they should do is check the alignment.This is under warranty and they should be doing what ever it takes to make sure the vehicle is fixed.The only other thing that can make it drift would be a tire.Have them swap the 2 front tires and see if it drifts the other way.If it does then you have a tire problem.If not then the alignment has to be off and should be adjusted.If possible try another dealership.Hope this helps.Good luck.
Jan 11, 2011 | 2011 Lincoln MKZ
Drifting belt.
Under the treadmill there are rollers at both ends. one of them is adjustable. If it rolls left and the adjustment is on the left side, tighten it. If adjust ment is on right loosen it. Do the opposite if it goes to the right.
Apr 23, 2009 | HEALTHRIDER Pro H500i Exercise Workout...
Suburban K1500 steering concern
the steerign gear was not centered when istalled. need to remove and count the total lock to lock revolutions and recenter the gear and reinstall
Mar 22, 2009 | 2001 Chevrolet Suburban
No R or L buttons on DS Lite
The R and L buttons are on the back of the DS.
Hope that helps
Feb 16, 2009 | Nintendo DS Lite Console
Drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
May 26, 2008 | Toshiba Tecra M2 Notebook
Protocol Predator SB 3.5-Channel Remote-Controlled Helicopter Logo
88 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
