Question about Bose RC-28S stereo expansion kit - White Remote Control
Bose remote won't change channels on sharp tv
4 Suggested Answers
  • 14 Answers
SOURCE: Remote
The IR "bug" provided with the Bose 18/28/38/48 models is an IR emitter which sends out IR control codes to another component. The system is designed to have the Bose remote control be used to control the TV and the dish box. The Bose media center has a strong IR blaster in the front which will flood your room with the IR codes to control your TV or Dish box. The TV sensing device must be placed at a location on the TV where specific voltages can be detected. The location will vary depending on display type you have - plasma, LCD, tube or rear projection.
Posted on Dec 24, 2007
SOURCE: i have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Posted on Feb 08, 2015
gopakumarg43
  • 75471 Answers
SOURCE: Ny Bose remote stopped changing channels
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Jun 30, 2016
I've had my Sony Bravia 52EX701 for over 3 years. We have two remote controls. The main one we use is through our older Bose Home Theater System to control the TV, etc. The Bravia remote is also activ
Maybe there has been a disconnect with the TV recognizing the code of the remotes? Or, maybe you pressed a button on the remote that will not allow it to change the channels. I've done this in the past where I accidentally pressed, say the TV or DVD button, and when I turned the TV on and tried to tune in channels, the TV would not respond. Pressing the cable button (but that is on my remote) returned the remote to its ability to change the channels. You will just have to do trial n' error.
Nov 30, 2014 | Sony Televison & Video
TV CONTROL ON SAME FREQUENCY AS BOSE, HOW DO I CHANGE THE FREQUENCY TO STOP THE BOSE SYSTEM FROM RESPONDING TO MY TV REMOTE
Go through the BOSE manual to see if another channel can be chosen to control the system. If not, try and locate them farther apart and shield the remote with your hand to avoid signal from getting to the unwanted device.
Nov 16, 2013 | Bose Wave music system Multi-CD Changer...
Sharp LC-37DB5U stuck on one channel. Won't respond to anything. Put in a new motherboard and same problem persists. Sound and picture are fine
I could be wrong, but it sounds like the TV hasn't gone through channel setup. You have to do this in order for the TV to "learn" the channels, assuming you are using cable. If you are using cable run channel search in the setup menu and see if that changes anything. Can you change channels by manually entering in the channel # and hitting enter?
Jan 06, 2013 | Sharp LC-37DB5U 37 in. HDTV LCD Television
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
When I first had my Bose home theater system installed professionally, my bose remote controlled my tv, cable box, and dvd player. I have 4 remotes including the bose remote. I thought the bose remote was...
If your remote worked everything for a few weeks and then quit, and you are sure the codes are correct, take the remote back under the 1 year replacement warranty and exchange it. It is defective.
Jul 31, 2009 | Audio Players & Recorders
Infrared Remote codes
try to go threw all codes when you turn on and off the tv after each code and try to change channel after each code then the one that changes the code is the correct code!!! this might help.
Mar 25, 2009 | One For All URC-3021 Remote Control
Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Sep 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Remote
Dec 20, 2007 | Bose Lifestyle 48 System
Bose RC-28S stereo expansion kit - White Remote Control Logo
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
