Question about Acer Aspire One A150-1006 Notebook
Hardware failing for hitachi HTS54S016B9A300 ATA DEVICE
HARDWARE FAILING
    Top Expert:
  • Acer Master
  • 22,095 Answers
Replace the hdd/hardware
Posted on Apr 20, 2014
IB4G2008
  • 3587 Answers
SOURCE: dvd does not work
maybe here...you'll need to dig down deep into the driver options
click here to find out
Posted on Mar 09, 2008
cpenzes
  • 1102 Answers
SOURCE: Restarted my computer and now it won't come back on! Help
right click my computer
then properties
hardware
then device
scroll down and see if you have anything with a ? or !
if you do click and update driver
if not let me know
Posted on Jan 19, 2009
SOURCE: Windows has encountered a problem communicating
I had similar problem with a Dell Optiplex 760 desktop . I went to BIOS disable external SATA and all additional ports which is not used like parallel and serial ports and it worked. I think its with SATA settings only .
Posted on May 25, 2009
  • 788 Answers
SOURCE: Windows boot manager-hardware failure
Try pressing F-8 and look for last known good working configuration.
If you are trying to reload from CD/DVD drive and it continues to boot into your old windows configuration, Enter your BIOS settings, and change the boot order to CD/DVD and then Hard drive
Posted on Sep 15, 2009
stormblade02
  • 28 Answers
SOURCE: i have problem with optical drive TSSTcorp CDDVDW
check your cables...
optical drives are ready to use if you are using windows xp...
try to replace your cables...
is the drive appears in your "my computer"??
Posted on Feb 03, 2010
I am having frequent BSOD and also flash/shockwave player problems.. what to do ???
I can only assume that you have added some new hardware to your system recently. BSOD is usually an indication of a hardware conflict, caused by new hardware, Remove any new hardware and try again, BSOD can have other causes although hardware is the most common. Hope this helps.
Jan 12, 2012 | Computers & Internet
I am trying to reboot but i need the dvd-rw driver says it ist found
where does it say this at? you simply turn your machine off and back on and when it gets to windows it says it isnt found?
well if you are able to boot into windows here is what I usually do to exactly identify hardware inside your machine
Right click My Computer > Manage this will bring up the Computer Management Utility, so from there on the left side menu you should see Device Manager, Click on device manager, and on the right screen it will list your hardware by device type, go into your dvd/cdrom device expand the + arrow, and it should list your device.
If there is an exclamation point yellow next to it means its not properly installed, if red x that means failing, so to properly identify that piece of hardware you click the dvd/cdrw entry of your drive and go to properties
from there you click the details tab on the furthest right side > from there you want to go to this in the drop down menu list : there are two you should check out the device instance id and hardware ids. for a cd rom it will list the hex value at the end of the string you are interested in ( hexadecimal example :ABCD:EFFF) or 1234:4321 thats how the hardware will be identified.... there maybe an ampersand & subsys its depending on your hardware, but check the device manager, if your hardware is failing, check those ID's and write those numbers down, and you can google vendor ID (first four hex) and Device ID (last 4 hex) and find your EXACT HARDWARE to a T, make sure if theres a subsystem to include that because that usually is motherboard specific.
hope this helps you out, if not try driverguide and search for your hardware driver
Jun 18, 2010 | Acer Aspire AS5520-5912 Notebook
Poweron laptop hdd not found
there is a problem on hardware get it to be checked
Nov 24, 2009 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Failed segate drive need replacement solution
Yes the ATA-300 is compatible with notebook computers.
I use Hitachi HTS7210 80GB.
Oct 07, 2009 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
C7280 hp all in one has failed the fax hardware test
I uninstalled and installed again and that seemed to have fixed the problem.
Dec 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
Unable to enable dvd writer
go into System Maintenance add/remove hardware and delete DVD , then reset to enable search for new hardware. should resolve.
Jun 21, 2008 | Computers & Internet
Dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Jan 04, 2008 | Dell Dimension 4600 PC Desktop
Acer Aspire One A150-1006 Notebook Logo
20 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
