Question about Dual XDVD8181 Car Video Player
JVC AV61 PARKING BRAKE BYPASS - Dual XDVD8181 Car Video Player
SOURCE: how do i bypass the parking brake switch in order for my video to play
ground parking brake
Posted on Mar 14, 2008
SOURCE: parking brake bypass
make sure you ground the e-brake wire (yellow with blue stripe) then turn the power on, insert a dvd, let it play until you hear a sound, then on the remote press: stop, stop, 2, 6, 6, 0, 4, enter.
Posted on Mar 25, 2008
j_del
  • 1586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 25, 2008
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Posted on Oct 09, 2008
SOURCE: bypassing car dvd parking brake
The yellow wire that the manual says that you "need to hook up to the parking brake" just needs to be grounded. Its that simple, you do not need any switch or anything, just find a part of the car behind the unit and ground it.
Posted on Apr 30, 2009
On a JVC KW-V50BT I want to bypass the parking brake setup. Can I just ground the Parking brake wire in the back of the stereo?
Without actually looking at the wiring - you'll need to provide the same voltage level to this wire that it sees when the parking brake is set . This is usually tied to either +12V or -12V. So, if the radio plays when it is grounded (or -12V), you can tie it any ground in the vehicle. If it plays when it is hot (+12V), then you'll need to tie it to any +12V source. Be sure you're connecting to a VOLTAGE source, and not a data bus that is found in newer cars.
Once you do this, the radio will be fed a signal regardless of the parking brake position.
Oct 19, 2015 | JVC Car Audio & Video
How do I bypass the parking brake wire ?
This is illegal and if stopped by the police , you will be prosecuted
Mar 21, 2010 | JVC Car Audio & Video
How do I bypass wiring up the parking brake wire
wire a switch pink to one end and the other to ground when you flip the switch the radio thinks its a brake.
Nov 25, 2009 | JVC KW-AVX810 Car DVD Player
How can i bypass the parking brake
Just connect the parking brake wire (coming from the stereo. it's usually a pale green) to chassis ground. But be aware that viewing video while driving is illegal in almost EVERY state!!
Sep 09, 2008 | JVC KD-AVX1 Car DVD Player
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
Ground the handbrake wire to the outerpart of the "line out" connector if it's not in use, works a treat
Apr 29, 2008 | JVC KD-AVX11 Car DVD Player
Parking brake bypass
The best solution and what i did was just plug the parking brake to the ground cable of the reciever...
And works perfect...
Mar 29, 2008 | JVC Car Audio & Video
Bypass parking brake
Does the suggestion by djBass work with the avx800 too?
Feb 16, 2008 | JVC KW-AVX800 CD Player
Brake bypass jvc kd-av7010
ground the e-brake wire to something other than the e-brake start the dvd when you hear sound press "stop stop" then enter the code 26604 then press "enter" you will have to do this every time you want to watch a movie but it works.
Dec 06, 2007 | JVC KD-AV7010 DVD Multimedia Center Car...
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Dual XDVD8181 Car Video Player Logo
42 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
