Question about Matsushita EME-278TY 1.44mb 3.5 Inch Floppy Drive P/N: EME-278TY - Mat
Broken belt Need a replacement belt
Broken belt
Please check on this link for tips to replace the belt
click on belt replacement
Jan 15, 2013 | Amana Washing Machines
I am trying to get the serpentine belt back on but it sems that the tentioner is not in line with the rest of the belt track. I think this is why i can not get the belt back on.
IF YOUR DRIVE BELT HAS BROKEN AND YOU ARE REPLACING IT AND THE BELT TENSIONER NOT LINED UP WITH BELT.EITHER TENSIONER BOLT LOOSEN OR TENSIONER IS BROKEN AND NEED REPLACING.
May 17, 2011 | Chevrolet Cavalier Cars & Trucks
Battery light turned on. Lost power steering and AC.
You broke your serpatine belt. Needs replacing. It's a $50ish part and easy to do if you have a diagram under the hood of how the belt fits. But if it was "rattling" for a couple of weeks take it in for crying out loud. Let the mechanic look it over to make sure your lack of vechile care didn't destroy anything under the hood.....
Jun 12, 2010 | 1998 Saturn SC
Broken drive belt on ryobi band saw, need
Just go to a well equipped hardware or auto parts store. Take the old belt with you so they can find an exact replacement. Good luck!
Apr 26, 2010 | Ryobi 9 in. Benchtop Band Saw
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
Replace a broken belt
Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 15, 2009 | Vacuums
Will not spin
make and model number for accurate diag, but most common problem is broken wqasher tub drive belt, turn washer on its side and check for a broken belt.
Sep 27, 2009 | Washing Machines
Broken drive belt
Take the broken belt to an industrial supply house or Ball Bearing supply house for a replacement.
Jul 10, 2009 | Black & Decker BR300 3''x18'' Belt Sander
Newly replaced timing belt was broken in my daewoo nubira 2000
Yes you should always do the water pump when doing the timing belt. belt tension too tight can cause the break as well as a bad water pump or idler pully, these should all be replaced when you do a timing belt to save yourself this exact headache later on.
May 12, 2009 | 2000 Daewoo Nubira
Need to replace broken belt
for 9.99 or 19.99 i would be happy to !
Mar 28, 2009 | Electro Brand Nostalgic Stereo CD Music...
Matsushita EME-278TY 1.44mb 3.5 Inch Floppy Drive P/N: EME-278TY - Mat Logo
55 people viewed this question
Top Matsushita Computers & Internet Experts
John Anderson
John Anderson
Shaukat Bhutto
Level 1 Expert
Are you a Matsushita Computer and Internet Expert? Answer questions, earn points and help others
