Question about Panasonic Audio Players & Recorders
F76 error code
Panasonic SABT737 Home Theatre System not powering up properly and displays error code F76 before switching off
5 Suggested Answers
SOURCE: SC-BT 100 Error Code f61
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
SOURCE: Remove casing for Panasonic SA-DT310
Figured it out. quite simple really.
1. Unscrew the 3 screws at the back that hold the plastic casing on (NOT the one that only go through the metal but the 3 that go through the plastic).
2. you can now slide the side plastic sections of the casing off.
3. underneath these side sections you will see that there is a small section of plastic on each side that can be pushed in which will then enable you to slide off the top part of the casing.
4. underneath the top plastic casing is further metal casing. unscrew the two screws toward the front that will then enable you to lift this inner metal casing off.
Posted on Apr 19, 2009
welcomejee
  • 10594 Answers
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
Posted on Sep 14, 2009
award462
  • 395 Answers
SOURCE: need manual and instruction for panasonic home theatre SA-PT560
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
I have a panasonic SC PT960 system. Haven't used in months. Turned on,got error code F76. Tried unplugging and plugging back in to reset, but it did not work. What is wrong with my system?
"F76" is a power supply problem. Could be something really simple or something much harder to figure out. These units aren't really user serviceable and it's way too old to still be in warranty(?) so maybe you've been whapped with a subtle hint to upgrade to a blu-ray HT system. You'd be able to keep the rest of the system and just replace the head unit.
Jan 02, 2017 | Panasonic Audio Players & Recorders
I have a panasonic SC-BTT190 home theatre system and it does not power up when I turn it on, what can I do??
double check power at the wall outlet, Check proper connection at the unit. It's possible the power on switch is bad.
Mar 21, 2015 | Panasonic Audio Players & Recorders
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
Apr 16, 2013 | Panasonic sa-ht930 Home Theater Audio...
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
Fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Aug 11, 2009 | Panasonic SC-HT17 System
Dec 24, 2008 | Panasonic SC-BT100 Theater System
Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Apr 06, 2007 | Panasonic SC-EN17 CD Shelf System
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
140 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
