Question about John Deere Garden
Gas comes out of the carb overflow tune whancock shut down
SOURCE: 2003 WR250 F - eng. won't idle down and carb starts to overflow
Hi Jwelden,
Have you checked the float level in the float chamber?
I guess you may have to reset the float pin adjustment, its allowing more gas to pass through thn required and thus the overflow!
Not bad too, when you are working on the float assembly take the opportunity to blow out the fuel line from petcock to the carburator via the seat for the float pin,any foreign particals there would stop the float pin to seal up and thus overflow.
Fit in an inline fuel filter , this will help keep out the dirt or whatever.
Hope this helps.
Knight (Yamaha Seca XJ750A 1981)
Posted on Feb 13, 2009
  • 3567 Answers
SOURCE: CRF230 - Throttle won't turn.
The overflow problem is a carb float being stuck open. Turn off the gas and drain the offending carb(s). Next, turn the gas back on and sharply tap the float bowl with the plastic handle of a screwdriver as the fuel bowl refills. The goal here is to vibrate the float to free it up. If doing this process a couple of times doesn’t free the float I would remove the offending carb(s) and clean with a spray carb cleaner. By the way, Check the float, it could be filled with gas instead of air. Clean the air filter then re-mount carb(s). Next, remove the water trap bowl at the bottom of the petcock, (gas valve). Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ). Install an in-line fuel filter.
The lack of movement in the carb slide is either a bad cable or the the carb is a CV model. The slide on a CV carb will not move unless the motor is running. Start the motor. Does it speed up normally when you twist the grip? If so, then there is nothing to worry about.
Posted on Apr 16, 2009
voodoomox
  • 1689 Answers
SOURCE: 87 yz125. gas pours straight through carb
change the needle and make sure its jetting right, check the floats if it is operational. '90 to '95 carbs are compatible, so if you are planning a replacement, you may use those
Posted on Jun 10, 2009
  • 75 Answers
SOURCE: gas overflow line coming from carb is pouring out on a 2001 kaw
the carb needs to be cleaned the float is stuck open and is over filling
cheap and easy fix
good luck
Posted on Jul 08, 2009
wayneman01
  • 301 Answers
SOURCE: Carb leakes gas out overflow
It doesn't take much to hang the float valve open. The smallest speck of dirt or debris will cause the float valve to not shut the flow of gasoline off. After sitting for that length of time, the carburetor needs to be completely disassembled and cleaned. Use an automotive carburetor cleaner (but do not put any plastic or rubber parts in the carb cleaning solution as they will be eaten up). While you've got the carb apart, inspect the float valve. Replace it if there's a groove worn into the tapered seat. Installing an in-line fuel filter may help, too.
Posted on Nov 16, 2009
Why is gas dripping/runnng out bottom overflow line of carb?
Could be one of the carb floats is stuck or the rollover caused it to come off its mounting position. As fuel enters the carb, the float rises with the fuel level until it reaches a position that shuts off any more fuel entering the float chamber and prevents an overflow. Fuel level drops, float drops and fuel flows again. Basically like the cistern in a toilet.
Feb 11, 2016 | ATVs
I was riding my bike and came to a stop it shut down and started to leak gas out the air intake now it will not start. What do I need to check to fix this issue
The floater is stuck 'open'
Fuel dumping out of carbs / overflow- 1998 gas flowing freely ...
www.cbrxx.com > ... > Engine / Airbox / Exhaust / Fuel Delivery
Sep 18, 2011 - 15 posts - ‎5 authors
It will start / idle - sort of, but dumps gas out of the overflow/ carbs. I. ... If the carbs are over flowing while the motor is shut down one might ... to the bowls with outremoval of the fuel tank and maybe the air box or a ... valve/ petcock diaphragm drain line you see leaking below the bike. ..... Motorcycle Forum ...
What is wrong with my carburetor? - Instructables
www.instructables.com/.../What-is-wrong-with-my-carburet...
InstructablesApr 24, 2012 - Shut off the fuel line, drain the fuel from the carb, disassemble and verify the correct ... Then I started to notice fuel coming out of the carb intake. ... the carb (blew air thru the fuel inlet), turn the carb over (float upside down) valve ... Carb still leaking gas at the intake connection, where the choke is located.
How to diagnose carburetor vacuum leaks on your motorcycle
? 4:41
https://www.youtube.com/watch?v=XzjSEYB9RDU
Feb 2, 2011 - Uploaded by mrmaxstorey
Not only did we have vacuum leaks, but the baffles were takenout of the engine, and the previous owner had removed the airfilter and ...
Carburetor / Carb Leaking Gas? How to Fix / Repair it ...
? 5:42
https://www.youtube.com/watch?v=gbfMEYG8NvM
Dec 26, 2015 | GAS Motorcycles
Gas keeps getting in with oil what do I do riding lawn mower
Happened to my Husky..Your mower is equipped with the EPA positive shutoff electrically operated valve on the bottom of the carb..it is designed to stop overflow of gas from the carb when the float sticks.. however when it fails the gas now flows back through the carb and into the cylinders and eventually filling up the crankcase and cylinders.. In stead of to the ground...You can replace it but eventually it will fail...the easiest and best fix is to put a easy to get to shut off valve between your tank and carb..When ever you shut your mower down for ANY reason turn off that valve before shutting it down..put mine on two years ago and hasn't failed me yet...Just need to remember never shut the mower down with out turning the gas flow off....NEVER....it may not fail but when you least expect it WALA oil in the gas...best is to shut the gas off and let it run for 20 seconds or so then shut the mower down..this assures no gas in the carb system cannot get into the oil...hope this helps pass it along to your friends as all newer motors are required to have them...good luck.
Apr 16, 2015 | Garden
I have a 1986 883 sportster. The carb is overflowing gas when it idles or sits . What could be the problem. Its been sitting a while.
Hi Anonymous, and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. Improper fuel level in float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaky float assembly.
7. Particle contamination in inlet fitting cavity.
8. Ethanol sludge, dirt, rust in bottom of fuel tank
Good luck
Jan 24, 2013 | Harley Davidson XLH Sportster 883...
Gas leaking through overflow
Your carbs need cleaning and setting,, the needle and seats are what controls the flow of gas into the float bowls... the floats movement (up and down) regulate the movement (opening and closing) of the needle and seat
Dec 22, 2012 | 2007 Triumph Triumph Bonneville
Mbk mach running problem
How much gas comes out of the carb when you stop? Do you turn off the fuel shut off valve when it is not on? It sound like you float in the carb is not working properly or or float needle is no good anymore because from the carb leaking gas thru the over flow the gas isnt getting shut off by the float and pin int the float bowl. These are relitivly cheap parts to fix if that doesnt seem to fix the problem then shoot me an email. Good luck A.J. Weaver
Apr 02, 2012 | MBK Motorcycles
Gas coming out of overflow on my 2000 polaris 500 4x4
The float is sticking. Sometimes a gentile tap on the carb will fix the issue. If that fails try shutting the fuel off until it runs out of gas, then turn fuel back on. If this fails, removal and cleaning carb is required.
Nov 02, 2010 | Ducati 900 SS Motorcycles
I have gas leaking from a hose that is protruding from the bottom of my 1998 Suzuki Savage 650 LS. It is backfiring a lot and I was told this was due to the Jardine exhaust system that is installed. ...
do u mean gas as in petrol??if it is petrol...then its leaking from the carbs..as this id the overflow pipe!!..if thats the case..then it sounds like the carbs may need cleaning. as they may be some muck in there thats stoping the floats from shuting.(carnt shut so overflows!!) this could make the bike backfire as still petrol going to engine when carbs shut so backsfire..or the back fire could be from the new exhaust .if its not seal'ed right on the manifolds it sucks air in & can make them pop & backfire when you shut the throttle(like when u shut throttle when coming up to a stop)....hope this helps...Howard
Jan 05, 2010 | Suzuki LS 650 Savage Motorcycles
KDX200 carb float set up. Hi I have gas coming
If you have gas coming out of the overflow tube, you need to make sure the float valve is shutting the gas off properly. The float height would have to be awfully high to cause gas to come out the overflow. You might be able to do it on the bike but it's a lot easier to do off the bike. Pull out the float valve and inspect the tip. Make sure it is smooth with no evident nicks or deep grooves.
Apr 18, 2009 | 1998 kawasaki KDX 200
Hi Jwelden,
Hope this helps.
Feb 13, 2009 | 2003 Yamaha WR 250 F
Garden Logo
12 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
