Question about Rinnai R85ePLUS Tankless Water Heater
Have a leak coming from the Rinnai tankless hot water heater R85
Tankless water heater is leaking while running the hot water.
cballard
  • 18 Answers
SOURCE: Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Posted on Dec 31, 2008
CRTN
  • 716 Answers
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Posted on Jan 16, 2009
  • 234 Answers
SOURCE: my r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Posted on Mar 15, 2009
  • 6 Answers
SOURCE: vinegar flush
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
Posted on Aug 01, 2009
  • 30 Answers
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Posted on Sep 22, 2009
Rinnai R85 starts to warm then stops and blinks 61??
I went to the Rinnai website and this is what I found for error code 61.
Error Code 61 Problem: Fan failure
Solution: Measure the resistance on the fan motor, check the damaged or loose wiring and connections. Make sure that the fan spins freely.
Sounds like either your fan is broken or something is keeping it from spinning freely.
Hope this helps.
Gary
Feb 24, 2015 | Rinnai R85ePLUS Tankless Water Heater
R85 tankless water heater
Probably frozen. Let it thaw out and see if it works. You may want to think about wrapping the pipes with heat tape because of those low tempertures they could break especially if the unit is outside.
Good luck,
Marty
Jan 07, 2014 | Rinnai Digital Remote Water Heater Control...
Rinnai 20 heater stopping and starting have changed regulator but still not working properly only started playing up i have been in house 2 years any more suggestions
Single-handle faucet cartridge that leaks can cause tankless not to function. Check for crossover or cross connection:
http://waterheatertimer.org/Crossover.html
Cut losses from owning tankless computer that heats water. Go to Lowes and buy new tank-type gas water heater for $390 and have hot water right quick with less maintenance and own a product that homeowner can repair themselves.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Otherwise call service technician who is qualified to work on tankless computer.
Gene
n
Aug 07, 2013 | Rinnai Webstone The isolator EXP tankless...
I have a Rinnai Continuum Model 2532 natural gas tankless water heater in my home. It takes about 45 - 60 seconds for the water to get hot at the faucet which is closes to the heater. This thing is...
clean filter on the cold side coming in and clean or replace the aerator at the sink, rinnai works on water flow, common problem if your water hardness to high or if you have iron in your water
Oct 04, 2010 | Rinnai Webstone The isolator EXP tankless...
OUTSIDE GAS MODEL NUMBER c85, WATER IS NOT HOT TAN...
I have two C85 Rinnai and one is turned off because it leaked... the other one does not heat water... I have it set on 120.
Where can I download a repair manual on these? I am in Nicaragua and dealer wants to replace them or something.
May 20, 2010 | Rinnai Digital Remote Water Heater Control...
My Rinnai R85 heater will not heat; it is leaking water. I installed the unit 24-26 months ago, and had no problem until today. The automatic starter will engage but the flame (pilot) will not ignite. The...
I just fixed a leaky R85. Fortunately it's the bypass valve, not the heat exchanger. Did your heater freeze up in this snow storm? Unplug the power, open the cover and see where it leaks. If water comes from the top, means crack on the heat exchanger, then it would be too costly to replace. If you can see the water gushing out of a valve, on the bottom of the heater, then it's an easy fix. The valve is fixable, you don't have to replace it. But still need to find out what causes the flame fail (error 12). I suspect the igniter got wet, dry it with a towel after you take out the valve. Removing the fan first will give you more room to work inside.
Feb 09, 2010 | Rinnai Digital Remote Water Heater Control...
My r85 rinnai water heater vibrates significantly and makes
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Jan 16, 2009 | Rinnai Webstone The isolator EXP tankless...
Rinnai R85ePLUS Tankless Water Heater Logo
14 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
