Question about Whirlpool Ovens
900 oven and gas cooktop
Oven does not heat
  • Whirlpool Master
  • 5,323 Answers
1.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
2.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
3.
4.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
24187308-rlcwkvmjohmhoaex2htic0pp-3-18.jpg 900 oven and gas cooktop - 24187308-rlcwkvmjohmhoaex2htic0pp-3-25.pngt/uploads/images/24187308-rlcwkvmjohmhoaex2htic0pp-3-25.png" alt="24187308-rlcwkvmjohmhoaex2htic0pp-3-25.png" class="h_mi" />
Posted on May 18, 2015
2 Suggested Answers
kojak18
  • 31 Answers
SOURCE: My Amanda gas oven Model no. AGS781WW is not
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Posted on Jun 22, 2010
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Cooktop works but the oven does not, is there a fuse in the oven because there is only a circute breaker for the cooktop?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 19, 2010 | Ovens
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
Jun 21, 2010 | Ovens
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
SMEG Oven SA9066XS
If this is an Electric over, the heating element is damaged. The device has a open connection. These element break down often. Usually, the manufaction will sell this whole element as one fixture. They are usually easy to replace.
If it is a Gas oven, the polit is out. Sometimes they go out, and its ok to relight them. But this sounds like an Electric over!
Oct 22, 2008 | Smeg Ovens
Install electric walloven under gas cooktop
cheked on installation guide available with product online
May 11, 2008 | Maytag MEW5530D Electric Single Oven
Ovens Logo
61 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
