Question about U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste...
Thermister open how do i fix the thermister open problem
  • 171 Answers
Replace the thermister
Posted on Apr 20, 2014
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Samsung dryer is showing TO, what does it mean?
Dryer thermister is open. Thermister Open. Thermisters will change in resistance with temperature changes. The control relies on reading from this thermister so it can make a determination of whether or not to turn the heat on. If it is open then the control don't know what the air temp is inside the dryer and therefore it shuts down and declares an error. The thermister is mounted on the blower where it gets the air coming out of the drum on the way out the back. The fuse is right next to it. I bet you would like a service manual wouldn't you? SAMSUNG DRYER MANUAL
Note: dryer error codes are on page 32.
Dec 31, 2012 | Samsung DV328AE Electric Dryer
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a canon IR 2870 Photocopier it detected error E000000-001
there is something wrong with your copier's fixing unit.FIxing unit is located on upper side of drum unit.you can see when you open copier left door.a caution about heat is displayed there.the main reason of this error is your fixing unit heater not working or its heat is not detected by thermisters.
check all connection , check heater status,check thermister contact or wiring .replace heater or replace fixing unit.
Jan 19, 2011 | Canon imageRUNNER 3030 Black and White...
Dell 1600n error - What does "open heat error" mean
1. Please check the thermostat in the fixing unit.
2. It may open due to over heat. replace it. clean thermister.if spoiled replace it also.
Jul 15, 2010 | Dell 1600n All-In-One Laser Printer
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
Canon gp 215 error e000 how do i solve the problem
This error points to the main thermister in the fixing unit not reaching high enough temperature. You'll probably need a new fixing film as the thermister for this machine is located within this unit (fixing film). Try restarting the machine, it may go away temporarily but will certainly return.
Jun 30, 2009 | Canon Office Equipment & Supplies
Error 77
Try opening the front panel, removed the toner and close the panel. The printer should try to warm up and then say to open the panel door. Then open the door, insert the toner, clos it and the machine error should clear.
If not ---- power off the printer for 15 minutes and power back on again. If that fixes the problem then OK. If not then go into maintenance mode -
Press and hold the menu/set key while turning on the machine. Wait until it comes completely up before releasing. It should say Maintenance in the display.
If not press function,*,2,8,6,4 within two seconds. It should say maintenance in the display. Or on some machines Menu,*,2,8,6,4 within 2 seconds.Once you get it into maintenance hit 91 to do a parameter reset and than 99 to get out of maintenance.
If this corrects the problem then OK but you may have a failing thermister in the fuser. If the problem happens again then change the thermister. If the reset does not work then either the thermister or the fuser lamp has failed. In rare cases there is a poor connection with the cables to the fuser.
You will have to reset the parameter again after replacing the fuser if you need to replace the fuser or repair it.
Jan 07, 2009 | Brother FAX-8070P Plain Paper Laser
U-Line Echelon Series 2075DWRRSS Refrigerator Drawer w/ Three Piece Organizing System: Stainless Ste... Logo
52 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
