Question about DIGITAL PRISM 3.5 ATSC-300 Portable Handheld LCD Digital TV - A
White screen and remote does not work - DIGITAL PRISM 3.5 ATSC-300 Portable Handheld LCD Digital TV - A
I have a new 6350 hdtv the remote has quit responding to channel change comands
Use any digital camera, turn it on, aim remote at camera's lens, press channel button on remote and look for a white spot on the camera's screen when channel button is pressed.
If you do see a white spot, the remote is working but the receiver in the set itself or the succeeding circuitry has failed- time for warranty on either set or remote.
Dec 25, 2014 | Televison & Video
LT26M1CA Bush TV white screen
Chroma Ic has damaged. It should be replaced. Seek tech support. This is a skilled work indeed.
May 27, 2012 | Bush Televison & Video
White screen on TV.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
The screen on my logitech harmony 1000 remote goes white.
I would advise you do a firmware update. With anything, if you can remove the batteries and get it to work, the firmware is usually the fix that will resolve the issue. If you dont know how to do a firmware update, just look at the link below!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10747
Hope this helps!!!
Feb 27, 2010 | Logitech Harmony 1000 LCD Touchscreen...
I dropped my RTI T3 remote and now the touch screen went blank (white light). Touch screen works, but icons are gone. I tried taking out the battery to reset, but still no icons. Help!
T3s and T2-Cs are very delicate and often go to the White Screen of Death WSoD when dropped. (a play on the term BSoD from windows)
The remote needs to be serviced to fix this. If you explain the remote goes to white screen when you call RTI they will understand.
their tech support number to get a return authorization is here. They will explain how to pack and ship it.
(952) 253-3136
Dec 26, 2009 | Rti Technologies Rti T1 Remote Control
My lcd white wire is not connected
Don't worry about the white wire. This is the antenna for the optional remote control...if you push the "find" button on the remote, if you have that option, the green status light flashes repeatedly. Press the other button, if it's in remote, and it'll take a pic.
Oct 25, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
White screen of doom.
If your screen is completly white then unfortuanetly the screen itself will be at fault & would need to be replaced. On some LCD models there is a small fuse on the drive board attached to the screen, again on certain models this can be accessed & replaced but there is no guarentee that this is the only problem.
Aug 17, 2009 | Televison & Video
DIGITAL PRISM 3.5 ATSC-300 Portable Handheld LCD Digital TV - A Logo
32 people viewed this question
Top DIGITAL PRISM Televison & Video Experts
Electro Med Services...
Are you a DIGITAL PRISM Televison and Video Expert? Answer questions, earn points and help others
