Digitech australia windows8 won't recognise my Digitech GE4134
2 Suggested Answers
SOURCE: I don't have a manual for a Digitech Audio radio AR1747
the power button doubles as a sleep mode button. If he keeps tapping the power button he will see 5 then 10, 15 and the adventerly ON this will turn off the sleeper function.
Posted on Sep 02, 2010
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
W do I turn off squelch control on a digitech DC-1065 marine radio hand held 5 Watt
Hi David,
Before I try to give advice, I need more info.
I possess a Digitech DC1065 UHF 80 Channel CB hand held, so there seems to be some confusion here.
I live near Perth, Western Australia.
Firstly, How many channels does your radio have?
If the answer is 80, then what you have is a UHF CB, not a marine band radio.
Marine band is VHF with 87 Channels, in Australia that is, and the default channel is always 16.
Digitech are an Australian radio manufacturer, so you'll get great backup service.
If your radio is not defaulting to Ch16, then I am right about it being a UHF CB.
Therefore, it is useless for VHF anything, let alone Marine band.
I'm almost 100% sure this is a UHF CB in your possession.
Try this to prove me right please.
Reply to me with your Country and nearest city, I'll then be able to find a solution for you real quick, though I believe I already have.
Looking forward to your response.
Regards,
Peter
Dec 21, 2012 | Motorola Walkie Talkie 2-Way Radio
Vocalist Live 4
U.S and Canada: 20 VAC, 60 Hz Adapter: PS093B-20
Japan: 00 VAC, 50/60 Hz Adapter: PS093B-00
Europe: 230 VAC, 50 Hz Adapter: PS093B-230
UK: 240 VAC, 50 Hz Adapter: PS093B-240
Power adapter requirement straight from the user manual. I am sure you are aware that a simple plug adapter in a tourist shop does nothing to convert 120v US to 240v AUS. Note you unit does not like temperatures above 40C. And you can get that in Australia.
Bear in mind the timezone difference if you try Digitech support in the US.
DIGITECH VOCALIST LIVE 4 Owner Manual Page 36
Dec 30, 2017 | Digi-Tech Digitech Vocalist Live 4...
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Mar 15, 2010 | Audio Players & Recorders
I Have Just bought a digitech xc4881.new pc with windows 7 64bit
That is it. Scanners are notorious for needing another driver when you use 64 bit OS.
Sep 16, 2017 | Office Equipment & Supplies
Digitech RP250
you can download an instruction manual for free from here... I am sure that it will help you. http://www.devicemanuals.com/guide/Musical%20Instruments/DigiTech/DigiTech-RP250-English-User-Guide-TmpVeE16WT.html
or ask your question of this forum... i am sure they can help :)
http://www.digitech.com/soundcomm/new_account.asp
Dec 26, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
