Question about Actiontec Qwest Model Q1000 4-port Wireless N Router
How to open nat while bridgeing wirless adapter and lan together
Trying to get xbox 360 to open up nat with a network bridged forwarded all ports upnp on when i disable nat i cant connect back to internet
    Problem Solver:
  • 12 Answers
Set the mac with a static ip and throw it in dmz
Posted on Jun 29, 2014
Need to open NAT for Xbox 360. Router is a Belkin DIR-628 and has already been port forwarded...
In order to open NAT settings for the xbox 360 you will need to enable Universal Plug N Play [UPnP]
To enable this setting in the Belkin DIR-628:
1. Log into the router
2. Click on the "Advanced" Menu on top
3. Click on the Enable UPnP: Checkbox
4. Click on the Save Settings Button
May 01, 2011 | Computers & Internet
Change xbox NAT to open configuration
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Nov 29, 2010 | Microsoft Wireless Network Adapter Xbox...
How to connect Ethernet cable through the pc to the Microsoft Xbox 360 elite Game console for Xbox Live, without buying a separate router ?
You will need a cat5 or cross over cable, plug it into the pc and xbox, if you use vista then it is quite easy, goto the startbar and goto connections, you should now have at least 3 connections.
your connection to the xbox and if you have wireless your wirless connection or wired connection to the internet and a connection with just numbers 14... or somthing like that. Note that xp does not allow wireless and wired connections to be bridged, i dont know if they have changed this through updates, but last time i did this it would not let me. I cant remember the program that does allow you to do this on xp, but as i can remember it is quite hard to do.
You will need to bridge 2 connections, your xbox connection and you internet connection, to do this left click on one of the connections just to highlight it, press control(ctrl) key and hold down, click to highlight the other connection, you should now have 2 connections highlighted, now right click on 1 of them, in the drop down menu you will see a tab saying bridge connections, click on that and it does the rest. After it has finished bridging the connection you should have a new icon in the network connections window, it looks like a bridge. You may need to restart your computer to make the settings take effect.
Now try to connect to live on the xbox, you should be able to connect straight through the computer to internet connection, and also if using vista access your media.
You may have a problem with your NAT type after doing this. Usually it says you have a strict NAT type, you will need to forward ports on your router to enable you to connect properly, do a google search for which ports you need to open in order to remove the strict NAT, you also search on how to forward ports using google, all the information should be there. hope this helps. Post back if you need further assistants.
Oct 02, 2010 | Computers & Internet
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
How to setup my xbox to my pc
You will need a network cable (cat5) if you have wirless you will have network card at the back of the pc spare, if you dont you will need a network expansion card, plug the cable into the xbox network socket, it looks a bit like a phone socket, and plug the other end into the pc.
The best windows for doing this is windows vista if you are using wirless internet because it allows you to bridge a wireless and cable connection together, windows xp will not allow this.
Goto network connections, goto start and bring up the menu and click settings, then click network connections, you should have two or more connections, 1 wireless and 1 wired, which will be your xbox, you will need to bridge connections, to do the you will have to highlight the both connections by holding CTRL and left clicking on 1 and then the other, now right click on the highlighted connections, a drop down menu should appear, with a option to bridge connections, left click that and a bridge icon should appear in the window showing that the 2 connections are now bridged, you will now be able to use the computers internet access to enter xbox live. You may find that you will have a strict NAT set up on your router, to avoid this you will need to forward some ports, if you get this far post back i will try to run you through this process.
hope this helps and good luck.
Aug 14, 2010 | Microsoft Xbox 360 Console
On my xbox 360 it says my nat type strict and wont let me join any gamescould you please help me to get my nat open?
This is generally an indication that your router is blocking some necessary ports. Access your router's configuration page, (look on your computer's network adapter for the gateway IP, and copy it into an internet browser,) then forward the appropriate ports to your XBox's IP.
Jul 21, 2010 | Video Game Consoles & Games
Xbox 360 connection withthe netgear WGR614v9
This is beacuse there is NAT on the router for which you need to open certain TCP/UDP Ports on the router . but firtstly you need to Bridge the Verizon DSl Modem set up the internet connection as per same .
Feb 13, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Can you help me please??
you need to setup a network bridge between the tower pc and the xbox 360
Select Control Panel/Network Connections and while hovering over Network Connections, right click and choose Open. This will open a panel that should list your network connections.
This image shows all my existing network connections. Yours may not have the same adapters. The two adapters that matter are your wireless adapter and your Ethernet adapter. They will have different names than mine because I have renamed them from their default values. I have highlighted the two adapters in the graphic below.
Step 2 If you have both Ethernet and wireless adapters (and you must in order for this to work), then both of them will be listed in the Network Connections panel. Using the ctrl-click selection method or the drag-area method, select both adapters.
Step 3 Right-click one of the adapters and select the Bridge Connections option.
Step 4 You will see a notification that the bridge is being built. This may take a few moments.
Step 5 Once the bridge is complete, you will see the bridge icon and the network adapters as shown below:
Step 6 The bridge is only partially complete at this point. To complete the configuration, you need to relate the network adapters to the bridge. I’m not exactly sure why this is because you have to select the adapters to create the bridge in the first place. This is my first bridge, so it’s possible there is a better way of doing it. But this process has worked for me. If you know of a more concise way of configuring the bridge, let me know and I’ll update the process.
In any case, select the bridge, right-click and select Properties:
Step 7 In the Properties dialog, put check marks in the network adapters that you want to bridge. Make sure you select the wireless and Ethernet adapters.
Step 8 Now, the bridge is complete. It will take a few moments for your laptop to finish the configuration, get a new DHCP lease and complete the connections.
To verify if your bridge works, connect the XBox 360 to your laptop’s Ethernet port and connect with XBox Live.
Dec 10, 2008 | Microsoft Xbox 360 Console
Actiontec Qwest Model Q1000 4-port Wireless N Router Logo
76 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
