Question about Sanyo Split System Air Conditioner
Air conditional water drip
Switch on air conditional a while it water drip
  • Yyyyy
    Yyyyy Nov 09, 2016
    Ttttttttthhhhhhhh mmmmmmmmhhhhhhhh this is really tasty
    Problem Solver:
  • 10 Answers
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Posted on Apr 21, 2014
Water dripping from air conditioning outlet when not switched on
When the A/C is not in use there is still condensation as your compressor will run at different times. Defrost is one, of course to cool the car is another. The condesation coming from that drain should be perfectly normal. My GMC Suburban drains all the time as well, and its usually because I leave my knob on the defrost setting even though the fan itself is off the compressor will still run as its hardwired to do so. If the compressor runs, the coil in your car will become cold resulting in the water you see. Hope this helps, thanks!
Jun 23, 2014 | Heating & Cooling
Celiera 51GW 18000BTU mini split a/c heat, water collects on top rear coil and drips into fan housing and comes out bottom
While cooling, water is supposed to drip off the evaporator coil and flow out the unit. That's a feature of air conditioning. You get a little bit of control of where the water drips to by installing tubing to conduct the water wherever you like, unless the outlet port is plugged up. Poke a toothpick up it and see if that unclogs it.
May 13, 2014 | Haier HEATER CPN10XH9 Air Conditioner
If i use my air condition,there's no water dripping
Hi you will only get water dripping out when the day is humid. Ross
Sep 14, 2013 | GE Heating & Cooling
Wall air conditioning unit is dripping water into my condo
I have a 20 year old one that drips after a while on a hot day. I put a small bowl to collect it. It could be old or the ac unit ins't tilted enough to go outside.
Sep 07, 2012 | Kenmore Heating & Cooling
Water dripping from hood
air conditioning flow its just fine
Sep 01, 2012 | Hotpoint Kitchen Ranges
Air condition wather in the interior car
Could be the drain tube is partially clogged. It is usually located on the fire-wall or down towards the floor pan under the car. It is usually close to where the A/C lines go thru the fire-wall. About 1/2 inch diameter sticking straight out but may have a 90 degree elbow pointing down.
Also, it's been extra hot and humid all over and moisture could be freezing inside the unit when on MAX A/C, then suddenly melting when switched to normal. This opens the outside air door and allows warm/hot air into the unit instead of recirculating the cold air inside the car. The drain may not be able to handle a large, sudden quantity of water.
Perform a "driveway" test. Open the hood, start engine and run the A/C on normal with the windows or doors open. Locate the drain tube by looking for water dripping. Once located twist 2 or 3 pipe cleaners together and verify the tube is clean. Then close the doors/windows and switch to MAX A/C. Check for water dripping. If it stops dripping, water is freezing inside and now you know why!
Aug 28, 2011 | 1998 Jeep Grand Cherokee
The unit starts to drip water inside the house down the wall of the window that it is in
What you will need to do is reposition the window unit to where it is slightly tilted downwards in the rear so that the water flows out the backside.
Jul 06, 2011 | LG Goldstar GWHD5000 wall/window Air...
I have a Goodman A/C unit model number AWUF36106BA and serial number 1010684384. It keeps shutting off on us and we have had a repair man come out and said the problem we had is the emergency shut off...
If the drip pan switch is shutting the unit down , this means you have a condensate drain issue. Be careful about wiring around any safety switch, especially if the furnace is in the attic or on a second floor. You could have water dripping on the ceiling. The drip pan switch is a safety switch. The best thing to do would be to inspect the furnace. The pan is underneath it. Look inside the pan if you can. If it is full of water, use a shop vac and vac the water out of the pan. If there is no water, you can locate the safety switch, take the two wires loose from it and just wire them together. Caution: This will be wiring around the condensate safety switch that could cause water to leak on the ceiling or floor depending where the furnace is. Don't go too long without getting someone out to clean the condensate drain out.
May 01, 2011 | Goodman CKL36AR36 Air Conditioner
Water leaks onto floor board from Air Conditioner, where is the air condition relief opening, I am sure the drip line is clogged.
caused by water running out the drip line and not falling off the drip hose due to improper angle.Water will run back down the lower outside of the hose and into the cabin.
Fixed my T&C by putting a tight rubber O ring on the engine side of the drip line neat the tip. Water will hit the O ring and drip off properly.
Jun 11, 2010 | 2005 Chrysler Town & Country
Dropping water
Are you loosing water from the inside of the radiator?...then it is a blown head gasket, or a cracked head/block. Is there steam coming out of the exhaust? Is the water dripping from the exhaust pipe and from the small factory hole in the muffler....then it is normal. Most likely, as every car with air conditioning, the evaporator core collects frost even in the summer and the A/C cycles to heat it, and melt it off. It is meant to drip through a small pipe, under the car, onto the ground. It is perfectly clear and clean water. It is normal functioning of the air conditioning. In the winter when the defrost is selected to clear the windshield, the automatic air conditioning produces cold dry air, which is then heated to clear the moisture. Frost collects on the evaporator core. The system cycles to heat it off from time to time and it will drip clear water in the winter when you didn't even know that the air conditioning was on. After all who needs air conditioning in the winter when you did not select it. The automatic system turned it on to dry the re-heated air to clear the moisture from inside the car.
Jan 21, 2010 | 1991 Subaru Legacy
Sanyo  Split System Air Conditioner Logo
127 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
