Question about Frigidaire Electric Dryer
Wont start till I pull on the cord to make connection.checked cord with volt meter,its o.k.help. stampvs@yahoo.com
  • stampvs Jun 20, 2009
    thanks for your replies.the cord and wall receptical check out o.k. the problem seems to be in the connection terminal where the cord attaches to the unit or in other componants that are fed from that junction. its a fridgidaire model #aeqb6000es2 may need tyo replace the terminal. your thoughts.
  • 5,911 Answers
If you have unplugged the unit and performed a continuity (resistance) check from the end of the power cord to where it connects to the terminal block at the back of the appliance, then the next logical step is to perform a voltage check of the wall receptacle itself. If the voltage at the receptacle is good, but you are having connectivity issues with the appliance plugged in, the receptacle terminals may have become loose, or you may have a power cord that has a loose or broken wire. This intermittent connectivity can cause the receptacle and/or power cord to heat up and cause a fire. With the appliance unplugged, connect an ohmmeter to either end of the power cord and perform a continuity check. Move the power cord to see if the readings are constant. If you have intermittent resistance readings, you have a bad power cord. If the power cord still checks good, then I would recommend having an electrician check your wall receptacle before using the appliance again. If you still have questions, let me know. I hope this helps you.
Posted on Jun 19, 2009
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
My 1988 sportster 883 converted to a 1200 wont turn over new starter and new battery
Hi Dbull53, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.Harley Davidson Wiring Diagrams and Schematics
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 29, 2013 | 1993 Harley Davidson XLH Sportster 883
2009 nightster starting problems
Hi Anonymous, perform the following tests:
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Nov 16, 2012 | 2009 Harley Davidson XL 1200N Sportster...
Why wont my bike start?
Hi Ctaylor, perform the following tests:
May 22, 2012 | 2006 Harley Davidson XL 883 Sportster
I have a kenmore electric range model #790.95032504 everything works except the oven i replaced the lower element with no luck.i used a volt meter and checked the outlet,where the cord attaches to the...
IT very likely could be the oven control, use your meter to check for 240vac at the element if does not have 240 volts ac the oven control probable isnt sending power to element. WHILE ACCESSING ELEMENT TO GET TO WIRES TO CHECK POWER UNPLUG AT WALL OR TURN OFF BREAKER TILL READY TO CHECK
Aug 03, 2011 | Kitchen Ranges
1992 yamaha fzr 600 genesis just went dead a day after riding. put new battery in and it worked for acouple days but wont hold a charge. its now dead again.
use a vom/ meter on current setting put in circuit ..take hot off battery attach one lead to bat + the other lead to heavy cable u just disconnected. but 1st charge bat to full. see current draw. start to pull one fuse at a time till current drops. that circuit is the culprit. then youll need to find out why is drawing w/ bike off. wire chafed ? minor short.. or when running meter on battery 14.5 volts not running 12.5 volts if the vovtages don't go up when running regulator or altinator is bad or bat wire .. get the manual.. a big help...
Mar 27, 2011 | 1992 Yamaha FZR 600
1997 chevy 1500 wont stay runing
Ok, first, you need a new altemator. When you pulled off the battery cable with the truck running . it caused a voltage spike and fried the voltage regulator, which is internal on this particular altenator. If you want to check to see if the altenator is charging, use a volt meter.
Since it wouldn't start after you put the new altenator on, it could be one of two things, either you got a bad altenator which happens sometimes or, you have a weak battery and the altenator is tryng to charge itself to death.
Apr 10, 2009 | 1999 Chevrolet Silverado 1500
My dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Dec 26, 2007 | Whirlpool GEW9200L Electric Dryer
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
