Question about Sewing Machines
Serger Needles Can I use regular sewing machine needles on a Janome MyLock 644D serger? The recommended needles are HA-ISP #11 or #14 which are flat on the backside just like a sewing machine needle.
  • Sewing Machines Master
  • 1,388 Answers
Janome Overlockers (sergers) are set at the factory with #14 Red Tip needles
For finer fabrics, the #11 Blue Tip is good
If the #11 breaks, then try a #14 as they are a little heavier duty
You can always:
Contact Us at Bargain Box
Have a look at the detailed descriptions on these links
Accessories Parts
Posted on Apr 21, 2014
bargainbox
  • 1388 Answers
SOURCE: My serger
Self threading is perhaps not exactly correct, however there is a guide with an armature to release the guide to enable easy access........have a look in you manual
Also take a look at this image and move the lever to use it.....all will be easier to see with the needle plate off ....until you become familiar with the operation
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: Janome MyLock 644D
Yes, the model I used had a self threading lower looper. Just put the thread into the guide and flick the switch
Posted on Jun 11, 2008
bilabon
  • 46 Answers
SOURCE: NEEDLES FOR SERGER SEWING MACHINE
Try the website www.pdsixty.com
They have every needle under the sun!
Bonnie
Posted on Nov 06, 2008
bargainbox
  • 1388 Answers
SOURCE: Janome Needle plate and needles hitting something underneath
The broken pins are called chaining pins and are tricky for the home user to replace without risking damage to the needle plate as they are difficult to remove and the tiny burr used to hold them firm can easily open up and no longer grip the pin.
There are only a couple of things under the needleplate that are likely to collide with the needles. 1. Lower looper - with the needles 2. Both Loopers colliding with each other - not with the needles 3. Needle guards attached to lower looper - with the needles 4. Fixed Needle guard - with the needles
If you remove the needleplate and VERY gently turn the handwheel you should be able to see and feel where the collision is occuring and have a better idea of the issue.
I would strongly advise that you do not try to operate the machine until you are sure that the colliding components are adjusted. Broken loopers are approx $65 AUD and guards, tho' only about $20 AUD require some finesse in adjustment. Chain Pins approx $6 AUD
My recommendation is to speak with your local Janome dealer for advice and an approximate price to repair, replace or adjust as the case may be.
Your country's Janome website is certain to have a Dealer Locator page to list the nearest to you.
This is one occasion where it is sensible to call on the people who do these things routinely rather than try to DIY and make a more expensive hash of it.
www.bargainbox.com.au
Posted on Nov 22, 2008
SOURCE: MyLock 634D won't serge
Check that your lower looper is actually threaded and not tangled with the upper looper (needle thread) when it moves. I wish they'd include pictures in the manual how to lay the thread.
Posted on May 18, 2009
How do I change one of double needle
No double needle on a serger. It takes separate needles.
Sep 20, 2016 | Janome MyLock 644D
My janome mylock 644d threads are continually breaking, have threaded the machine correctly, will sew for a few centimetres and then thread breaks. Any suggestions?
If you have not already done so, try changing your needles. Sometimes the needles will be slightly bent or dull and cause thread breaks. If this does not help check your tensions. These should be set somewhere between 4 and 6 generally. If one is far out of this range, try resetting it. If you try both these things and still have trouble, it is likely that your machine is out of time. In this situation it would be best to take your machine to a reputable sewing machine repair shop for repair. Retiming a serger can be very difficult for a novice, and can be quite and unpleasant and tedious job, best left to a professional who is well versed in serger repair.
May 01, 2014 | Janome MyLock 644D
Neddles to suit janome mylock 134.
The needles required will be listed in your manual, if you don't have a manual then buy any needles recommended for sergers/overlockers. Or check on the Janome website.
Nov 23, 2013 | Janome MyLock 634D Mechanical Sewing...
What twin needles do I get for my overlocker ,It is a Janome Mylock 134D Are the needles universal or do I have to get a special one for this machine
I think Janome Mylock 134 has 2 separate needles. They are #11 or #14 for sergers and secured by 2 independent setscrews. I saw on ebay the instruction book with the owner's handbook for Janome Mylock 134D.
Jun 23, 2010 | Janome MyLock 644D
I bendt my needles, and after changing them it wont sew. the threads just come out without getting sewn together.. just 4 straight threads..
Once the thread breaks, the serger usually has to be re-threaded - all four components of the serger.
Raise the antenna to it's highest position.
Open the tensions to zero.
Turn the handwheel so the the loopers are at their highest position. Some sergers have a mark on the handwheel that aligns with a mark on the side of the serger for this step.
Thread according the the sequence indicated on the threading guide - this is either on the inside of the door or on the serger.
Mar 14, 2010 | Janome MyLock 644D
Upper looper will not saty trheaded to sew what
You have to thread the needles last.
1 - Take the threads out of both needles.
2 - Thread both loopers according to the diagram on your serger.
3 - Thread the needles.
If this fails, you need to bring it to a pro for service.
Feb 11, 2010 | Janome MyLock 634D Mechanical Sewing...
What needles are used by my Janome Model 134D serger?
my overlocker is a janome and i use generic overlocker needles; these are all rounded, not flat on one side. i hope this helps
Jan 29, 2010 | Janome MyLock 634D Mechanical Sewing...
Machine is threadedand makes the serger chain for
My janome 634D driving me crazy . I have tread it properly and it wont stitch ?
Nov 06, 2009 | Janome MyLock 634D Mechanical Sewing...
My serger
Nov 09, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
67 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
