Question about Drills
Milwaukee rcu60b charge stopped working
My 18v Milwaukee stopped working battery charged. What could be wrong?
possibly dirty contacts from battery to the motor .
Apr 13, 2018 | Milwaukee Drills
My charger will not turn on nor charge . Milwaukee 48-59-0255....
The unit has a fuse mounted inside on the board. If you don't know electronics, I would replace the whole charger.
May 24, 2015 | Milwaukee Tool Milwaukee 48 59 0255...
I have purchased three milwaukee screw guns in the past year and a half and all four of my batteries will not charge. when my first set stopped working i had to purchased another screw gun and within six...
The same thing happened to me. There is normally a 2 year warranty on the batteries from Milwaukee. You can't return them to the Home Depot, you have to send them back via a local repair center.
You won't be able to exchange the batteries at the repair center. The repair center sends them back to Milwaukee and Milwaukee will send replacement batteries. You will probably be able to find the closest repair center on line.
Sep 15, 2010 | Milwaukee Tool Garden
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
Dec 05, 2009 | Milwaukee 2610-20 18V Cordless M18 High...
I have 28v milwaukee tool kit and the batteries, both of them, went out at the same time. Strange! Upon charging the light on the charger blinks red and green. The batteries will not charge. Whats up with...
you can try and unplug the charger for a couple minutes and then retry. I have a LiIon at work and sometimes it does it also, if not then the batterys would probably be bad, I would contact Milwaukeetool.com and see about warranty replacement for these. They have a good warranty on the newer products.
Oct 28, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
Milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
May 27, 2009 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Milwaukee 28v battery problems
Take a look for warranty, and contact them ... If your warranty is out of date, than you must get new one. The best place is amazon for sure, Milwaukee 48 11 2830 M28 Lithium Ion Battery Pack. Hope this was helpful, cheers
Apr 14, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
2 Milwaukee 18VDrills stopped working - NEED repair help
This may not be as easy as you think. The first one my have trouble with the trigger switch, but it could be the motor. Without checking continuity, or replacing them individually you will not be able to tell which one is bad.
Another problem could be the brushes. That is what is most likely wrong with the 2nd one. Remove the 2 black screw caps on the rear of the drill, and remove the carbon brushes. Do they look worn? If so they will need to be replaced. If this is the case the motor may be breaking down, and wearing the brushes down too fast.
The good news is that Milwaukee Tools, offer a 5 year limited warranty, If you have a receipt, or can read the serial number. Take it in, or mail it to a service center. They will take care of it for you if they are less then 5 years old.
Dec 29, 2008 | Milwaukee 0822 24 V18 Driver Drill Kit
Drills Logo
42 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
