Question about Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
Power to gauges
What wires do I hook up to power up gauge cluster on a 2002 yahama xlt 800 to show hours on ski?
  • Yamaha Master
  • 1,103 Answers
Where does the voltage come from for the dashboard gauges grand caravan 2003. Have no gauges Checked fuses and relays all are good. Looked over wiring diagrams but looked like computers are together.
Do the light's on the instrument cluster work ? Fuse #24 - 20 amp location intergrated power module , under hood fuse box . Probably the instrument cluster it's self is bad , but without testing that would be a guess . Hooking up a factory or professional scan tool to view input's to the instrument cluster would be the proper way to diagnose. Gauge info to the Instrument come's over PCI serial data bus . A communication network for the control modules on the vehicle . Gauge info. come's from the PCM - powertrain control module. Your best bet , take it to a qualified repair shop ,dealer etc....
Oct 29, 2017 | Cars & Trucks
Mazda b2200 fuel guage not work sending unit new
Check the wires going to the instrument cluster, and check the wires from the sending unit. Possibly a corroded or damaged wire/connector
Sep 26, 2017 | Mazda Cars & Trucks
2002 Chevy Tahoe, all gauges and Speedometer stopped working......please help
Check voltage and ground circuits for instrument cluster. If that checks out, I think there is a problem with instrument cluster, itself.
Any applicable trouble codes?
Some makes and models, you may be able to get cluster to do a self-test? To do that, you may need a scanner that can communicate with instrument cluster.
Apr 30, 2016 | Cars & Trucks
Why does the fan not come on when the heat gauge goes into the red the alarm comes on but the fan still wont come on
Could be a fuse for the fan, possibly using a different thermal for the fan than the gauge and the thermal is bad. Try hot wiring power to the fan, see if the fan even works.
Mar 16, 2016 | Ski-Doo 2009 Expedition TUV V-800
How to replace the gas gauge
If the needle doesn't move at all at any given time from the resting position then the gauge is probably the problem. To test and/or replace the panel (in most cases, the gauges are together in a cluster panel, thus needing to replace the whole thing) you'll have to pull the dash, or at least part of it. To do it yourself, it's best to try and find a wiring diagram and/or make physical or mental notes of what plugs you removed from where. There's several resources to learn how to test the gauge for power (essentially, if the wires to it are working correctly, then it must be the gauge cluster). Your dash may be more simple though, it all depends. I've pulled a few dashes, and generally they take a few hours to pull apart then put back together (not including the time it takes for whatever your repair/testing takes).
Another issue could be a short in the wire to the fuel gauge, which can be tested for by simply testing the wires and seeing if the ground wire grounds and the positive wire provides power.
Similarly, a fuel tank sensor can be an issue if the gauge and wires are ruled out. Generally this is shown by a fuel gauge that fluctuates/bobs unnaturally, but other similar damage to the mechanism can result in a gauge that doesn't move at all. In this case you'd have to get this replaced, which isn't the cheapest or easiest job (whole gas tank needs to be removed, and the part isn't cheap).
Apr 02, 2013 | 2000 Pontiac Montana
2002 dyna low fuel gauge is not accurate
Hi Anonymous, you could have a faulty sending unit or guage, there could be a problem with your wiring. On models with the fuel gauge posing as a left hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
May 30, 2012 | 2002 Harley Davidson FXDL Dyna Low Rider
02 jeep grand cherokee 4.7 eng
Hook up a manifold gauge (mechanical temporary use gauge, used by mechanics) and test the oil pressure. You probably need to replace the gauge. The computer sends info through a printed circuit board behind gauge cluster and sometimes you have to replace the whole gauge cluster.
Feb 05, 2009 | Daewoo Leganza Cars & Trucks
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
987 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
