Question about Beverage-Air Beverage Air KF48-IAS 44.9 Bottom Mount Freezer
Beverage-Air KF48-1AS not coooling, fans not running
We recently had a Beverage-Air KF48-1AS donated to our soup kitchen/food pantry. Looks in pretty good shape, but we can't get it below 40 degrees. Ice and frost build up The fans at the top of the unit never seem to kick in. Any ideas?
  • Beverage-Air Master
  • 1,262 Answers
Http://www.beverage-air.com/uploadedFiles/docs/CFG_CRG_KF_Series809-046A.pdf
go to this web site and get your manual. check it out and if you have any questions, drop me a line
Posted on Jul 11, 2010
How to make salty food not salty
      Dilute. For soups, stews, sauces or anything that can be diluted, try adding a touch of water, stock, tomato sauce or juice. This will give thesalt more volume, thus spreading it out and making the overall dish lesssalty.Jul 24, 2012
      In a pickle: How to fix overly-salty food - SheKnows
      www.sheknows.com/food...recipes/.../in-a-pickle-how-to-fix-overly-salty-f...
    Feedback
Jan 23, 2016 | Cooking
Unit lights come on, evap and condenser fans working, compressor comes on and kicks off in less than 10 secs. this was giving to a church pantry. list of what to try. instead of buying parts.thanks
From the sounds of it, it is possible that the start capacitor is bad or the compressor is locked up. One thing to try is replace the capacitor. The other is to get a hard start relay kit.
Jan 27, 2015 | Beverage-Air LV451 Glass Commercial...
MT27 has a noisy fan operation. Doesn't always make the clacking sound, tried leveling the machine, cleaned condenser coils. We bought this unit 2nd had for our church's food pantry to keep the meat cold...
There are a couple of possibilities that could be causing this. I believe it is the fan blade. One could be that bracket that holds the fan motor in places could have loose screws, which would cause vibration. Another is that the mounting for the fan motor to the bracket could be loose. Another could be that the fan blade itself is slightly bent. Check the motor brackets screws, fan mounting screws and the blades. If all those are good, making sure the unit is unplugged you can turn the fan blade by hand slowly to see if it is dragging anywhere on the shroud around the coil or the coil itself. You could slightly bend the "clacking" blade to clear is that is the issue.
Tom
Oct 08, 2017 | Beverage-Air MT27 Beverage Cooler...
Beverage Air cooler
I am assuming that you are talking about he compressor having an issue starting. The switch is probably a anti-sweat heater. Turning it off, helps prevent a voltage drop which will cause a compressor starting issue. I believe your circuit is just too close to maximum. Your issue is usually caused by an undersized wired circuit to handle the starting amps needed to get it running. If you could put it on a dedicated, 20 amp circuit, your issue may just go away. Check it out.
Dec 19, 2009 | Carrier Beverage-Air MT21-1 Commercial...
some thing wrong with the evaporator fan motor. make sure the motor turns freely. your going to need service .
Jun 19, 2009 | Carrier 44.9 cu. ft. Upright Freezer...
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
Fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Apr 01, 2009 | Beverage-Air MT17 Refrigerator Commercial
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Wont cool
1. try cleaning the condenser it's gotta to have some dirt.
(if it looks clogged, turn the unit off and spray the condenser with a water hose!) it should throw out some dirt
if you did step 1 and still no cooling suspect a small refrigerant leak.
most of the times if its r-134a, i go down to autozone and buy a stop leak for r-134a and charge it into system.
also if theres a refrigerant leak,i'd get a tech to check and correct leak (if he finds it) but that's worse case scenario :) I'd go with dirty condenser.... email me at hvac.tech7872pr@gmail.com if you need more info.
Apr 23, 2008 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air Beverage Air KF48-IAS 44.9 Bottom Mount Freezer Logo
257 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
