Question about Shindaiwa Garden
When you throttle to engine stalls
EB802RT / Shindaiwa Blowers when you squeeze the throttle the engine turns off but it idles fine
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Posted on Jun 05, 2009
  • 430 Answers
SOURCE: Shindaiwa Blower - when throttle pushed, engine
Its not flooded- its lean.
Heres a way to test me. Try to give it throttle but keep it running. At the same time slowly close the choke. does it run better as you close the choke? Does it run pretty good on half choke?
Rebuild the carb, replace the fuel lines and fuel filter.
Posted on Dec 20, 2009
Starts and idles ok.stalls when throttle is squeezed
You might want to adjust the high side of the carb. but before doing that turn the high side jet to the right and count the turns so if it make no difference when you adjust it you can put it back to the point you started. If it won't adjust and run right then you will probably need to rebuild the carb. YouTube.com have videos on how to do this and it is not hard. Good luck
Jan 19, 2014 | Troy Bilt TB4SC 25cc 4Cycle 150 MPH Gas...
I have a 96 f150 5.8 4x4. Starts fine and runs fine, but when I start it after a 5-10 minute stop (when its warm), it will start fine but then die after a minute or so. It starts right back up and I hold...
Common issue on this year and engine, Do the cleaning outlined below.
Throttle Body Cleaning
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
Jun 08, 2017 | Ford F-150 Cars & Trucks
Engine will not run at full throttle. I replaced the plug, mixed new gas, replace the air filter and tried adjusting both throttle screws. the engine starts easy,and idles fine.
You could have a carbon problem try taking off your muffler and check for the exhaust port for carbon if so I would take it to a good small engine mechanic to get it removed as it is rather tricky as the engine has to be pulled apart.
Jul 25, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Do you use 2 cycle or 4cycle oil for mix in shindawai blowers
Not knowing what model blower you have, I do know that Shindaiwa manufactured both two cycle and 4 cycle blowers. In either case, you run the required 50:1 ratio. I would also recommend using the Shindaiwa branded oil since it is formulated to run in their equipment at that ratio.
Other manufacturers have 4 stroke blowers on the market that run "straight" fuel because they have an oil sump for the engine oil, much like a 4 stroke lawnmower. However, that is not the case with Shindaiwa's 4 cycle design which still runs "mixed" fuel.
Feb 20, 2011 | Echo Back Pack Blower Rack Fits Stihl...
Where is the idle air control valve
Here is a web site to show you a picture of what you are looking for: http://www.theautopartsshop.com/auto+car-usa+parts/ford+focus+idle-air-control-valve.html
Here is how to fix it:
  • Unplug the electrical connector on the IAC valve located on the back of the throttle body near the firewall. No tools are needed to unplug the connector. Squeeze the release tab on the plug and pull to remove it.
  • Unbolt the two 8-mm attaching bolts attaching the IAC valve to the throttle body using an 8-mm socket and socket wrench from the socket set. Remove the IAC valve and gasket from the engine compartment.
  • Position the new valve and gasket in place on the throttle body, and bolt it to the throttle body using the 8-mm bolts and the socket and socket wrench. Avoid over-tightening as the throttle body is easily stripped out by over-tightening the fine-thread 8-mm bolts. Plug the electrical connector into the new valve, and push it on until it snaps into place.
  • Turn the ignition key to the run position but do not start it at this time. Unplug the electrical connector once again, and turn the key off.
  • Start the engine, and adjust the minimum air rate by turning the adjusting screw located on the throttle cable side of the throttle body until the idle speed is 650 rpm plus/minus 50 rpm. Turn the engine off, and plug the electrical connector back in--pushing until it clicks into place.
  • Feb 04, 2011 | 2000 Ford Focus
    2006 Envoy stalling when idels and won't stay running
    Clean your Throttle body and pay attention to the Idle Air Control (IAC) valve passageway to try to clean the IAC. A dirty or faulty IAC will cause your engine to stall at idle, the job of the IAC is to open the passage way through the throttle body to regulate the amount of air to enter the engine to keep it from stalling when the Envoy is at idle.
    Start with the simple and clean the throttle body and inspect any loose or damaged wire leads to the throttle body. Replace or repair any signs of damage.
    Thank you for using Fixya and good luck.
    Apr 10, 2010 | 2006 GMC Envoy Xl
    Shindaiwa Blower - when throttle pushed, engine sounds flooded and it dies. any thoughts on how to fix?
    Dec 20, 2009 | Garden
    Hello, I have a Poulan Pro 25cc gas blower, 1 - 2 years old. Model #BVM200VS : Serial #07303N201072-1. I can get the engine started within 2 to 3 pulls, however, the engine will not idle - if I let go of...
    Remove the spring loaded screw.Then clean the end of it.Replace it.Screw it in tight and then losen one and a half turns.hope that was helpfull.
    Jul 31, 2009 | Garden
    Shindaiwa model t25 weedeater won't keep running after fuel in squeeze buld has been exhausted
    I had same problem, and changed diaphrams, but carb will not adjust or run without choke on. I am thinking control module. $55.95 or coil @ $51.00.
    Jul 14, 2009 | Garden
    Garden Logo
    77 people viewed this question
    Top Shindaiwa Garden Experts
    Dennis Key
    Dennis Key
    john h
    Are you a Shindaiwa Garden Expert? Answer questions, earn points and help others
