Question about HEALTHRIDER H79t Treadmill
Consoled stopped working
The treadmil will start working okay then about five minutes in none of the buttons work. The treadmil still runs but is **** at whatever speed and incline it's at.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: incline works all button works but the start
If you have a unit where the start button is not working most of these units will make some sort of beeping sound if you depress start button and no sound it maybe the key pad itself is causing this problem. Depending on manufacturer you can purchase the keypad/overlay and some will want you to purchase the entire display.
Posted on Mar 01, 2010
outfield502
  • 79 Answers
SOURCE: Treadmill turns on but none
just change the keypad
Posted on Sep 15, 2010
  • 48 Answers
SOURCE: My Healthrider R65 was in a flood. The treadmill
motor does not start as flood rusted contacts and brush commutators
open it and clean it
Posted on Nov 23, 2010
Part of treadmill buttons won't work?
Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair and service then check the following link.
http://electro-medical.blogspot.com/
Aug 20, 2016 | HEALTHRIDER T650I Treadmill Front Roller...
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
My Sole treadmill goes starts speeding up and there is no way to slow it down. I have to turn it off
RUN THE SOFTWARE CALIBRATION FOR EASY DIAGNOSTIC, TROUBLESHOOTING, AND FIX IT.
GOD BLESS YOU
Sep 22, 2012 | Exercise & Fitness
Some of the Vision Fitness t9450 treadmill incline and speed quick keys stopped working along with the manual speed and incline buttons
It sounds like you have a membrane issue. There are a number of different T9450 models and they all have slightly different consoles. You'll need your serial number to help pinpoint the parts you need. Your best bet is to go through the manufacturer (johnsonfit.com) and have them help you get the correct membrane and overlay.
Jun 08, 2017 | Dmm Vision Fitness T9500 Treadmill
When I turn on the treadmill, the top console lights up, but the bottom half of the console won't work except for 2 buttons. The START button will start the treadmill at 1 mph (stop will not...
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Jan 02, 2011 | Nordic Track NordicTrack Treadmill, A2550
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
HEALTHRIDER H79t Treadmill Logo
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
