Question about Boating
Suzuki outboard my 2007 Suzuki 6hp 4strokei can get it to idle but when I go over the idle mark the motor cuts out I don't know why can anyone help me out please thx
    Genius:
  • 1,056 Answers
It sounds like it is starving for fuel. Do you store it out of the water over the winter? Or do you use it all year round? If it gets stored, you probably need to get the entire fuel system cleaned out. If you use it year round; when was the last time it received a full service? It could be worn out parts. Age is the enemy here; motors do different things over time depending on how they're used.
Posted on Apr 20, 2014
4 Suggested Answers
goldbill
  • 184 Answers
SOURCE: I have a 2007 Suzuki df70 4 stroke outboard motor that when put in a higher gear than trolling sounds like a tapping noise coming out of motor, also a loss in power.(noise sounds like a card that a ki
Most manufacturers demand the water pump be changed every 3 years.
If your thermostat sticks, you can over heat. You would also need to ignore or have a failed temp buzzer. Also at extreme temps, your temp sensor can burn up. SO if you heard the buzzer, and then it quit- that did not mean you were out of the woods.
If you could still run on your scalded pistons, I would think a light bore job with new pistons would fix it.
Posted on Oct 14, 2012
SOURCE: My Suzuki 140hp 2003 outboard cuts out and will not start again untill 5-10 mins. The check engine light stays on and buzzer does not make a sound
sounds like a thermostant its that or overheating could be a water pump impeller
Posted on Oct 15, 2012
rilaxson
  • 456 Answers
SOURCE: suzuki outboard motor dt 28 will not spark
Have you checked the kill switch,make sure all earths are grounded
Posted on Dec 03, 2013
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
Suzuki
https://www.tradebit.com/filedetail.php/142965517-suzuki-outboard-service-manual-df90-100-115
May 02, 2016 | Boating
My question is about a suzuki outboard motor not a washing machine
PDF]Suzuki Outboards Workshop Manual - Manuals ...
www.motoren.ath.cx/outboard/suzuki-outboards-workshop-manual-1.pdf
This manual covers the topics that a factory service manual (designed for ..... include rudders, brackets, outboard motors, outdrives, diving platforms, or.
Oct 07, 2015 | Boating
6hp johnson outboard repair
cut down or oil in mixture. test tanks never a good idea as that is too much load for small motors
Jun 25, 2014 | Boating
Not running
I would check all of your fuel delivery system first. Make sure your gas line at the motor end has pressure and that you haven't hooked up the hose in reverse ( it happens). If fuel squirts out when you push in the little ball with a pointy object, you're good. Next, I would check the screen /filter on the fuel pump and maybe clean up the screen with a little carb cleaner. If it was running good last time you used it, the last thing I would mess with is the carb.
Apr 20, 2014 | Light Outboard Motor Boat Bass Fishing...
Suzuki outboad 6hp 4stroke
outboard motor yes ? only run in a tub or water attachment turned on before starting ! after 2 or 3 min the choke should be able to go off ! if not then remove the carb and clean jets etc with carb cleaner ! been stood a while ? fuel older than 5mths is off so replace also ! ??
Apr 20, 2014 | Motorcycles
Suzuki outboard motor dt 28 will not spark
Dec 02, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
Removing and replacing a carburetor idle mix screw with stripped head
Reverse drill bit might work. And yes they do make easyouts that small.
May 14, 2017 | 2007 Suzuki Boulevard S40
Suzuki outboard boat motor 250 hp four stroke 2012, good motor?
Excellant! Just hope you're not putting it on a light boat... that thing could take flight if you're not carefull. Suzuki can build motors - others are copying thier racing designs.
Jun 13, 2012 | Suzuki Motorcycles
Boating Logo
105 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
