My technics wont turn on it comes up f 61 on display thn turns of
  • 4,234 Answers
The F61 is an indication of "protection mode" for your unit. This means that a problem was detected in the final stages of the amplifier and the unit is shutdown to prevent further damage. Because of this indication, I suspect that you have a shelf unit. These usually have an AMP-pac or large IC as the amplifier stage. These are not cheap. Depending upon your model, the cost will range from $65 to $95 for the part alone. If you update this with the model number, I can provide the exact part number and cost.
Dan
Posted on Jun 29, 2009
I turn my pc on and it come on but it wont boot up. After several times of turning it on and off it boot up but tell me the system is fixing the problems. Aftrer about 5 minutes of the system fixing...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 26, 2011 | HP PAVILION M8200N PC Desktop
Hiya my 6500 slide when i turn it on nokia comes up thn thy shake hands thn the screnn turn on and off thn it stays off can u tell mi whats wrng wiv it plzz
the power is not enough to stay your phone on. Your battery is ok, but the phone is not on its perfect condition. Go to nearest phone technician for check up. thanks
Jan 09, 2011 | Nokia 6500 Slide Cellular Phone
Wont tick over
if you have made no changes to it what so eva and it has done this unexpectidly thn it must be someone has messd around with it this could be the air screw if you screw in all the way and unscrew 2 and a half turn as a round guide thn start her up if this is a twin or triple or 4 thn they must all b the same if this does not work thn raise the tick over also on all carbs still no joy u may hav a split inlet manifold rubber or blockd air filter or u may need to dismantle carbs and clean out pilot jets gd luck
Apr 07, 2010 | 2008 Yamaha Yamaha G5
Phone turns on and off but wont start
try using ur phone while plugged in charging. if it works thn ur battery defective
Aug 05, 2009 | Nokia 6500 Classic Cellular Phone
Samsung 61"DLP wont turn on.
The lamp is easily removed to check if blown.If it is blown replace. If it is not, you may have a bad ballast.
Jul 11, 2009 | Samsung DLP HL-P5663W 56" TV
Compaq mv540 monitor does not come on when i turn the computer on. the green on line turns orange
in a technical language you can say its a display problem. the monitor is fine.its actually the problem inside the pc.either some connections are loose or the ram memory needs to be cleaned or some part is gone faulty which needs to be checked.if any of this happens the display wont come.check all the above possibilities to reach the cause and solve the problem. please do rate the solution,thanks.
Jun 12, 2009 | Compaq MV 520 Monitor
Hi fi wont turn on !
hi. im assuming its a technics / panasonic system judging by the F 61 error code? try testing the cooling fan at the rear (assuming it has one) i once had the same error code on my technics amp and it turned out to be a faulty cooling fan. after replacement out of a scrap unit, the amp worked perfect.
Aug 07, 2008 | Audio Players & Recorders
Mutant mt2000 car cd radio
PRESS THE DISPLAY BUTTON AND HOLD DOWN THE CLOCK WILL FLASH TURN THE VOLUME KNOB RIGHT TO CHANGE THE MINUTES AND LEFT TO CHANGE THE HOURS THN PRESS DISPLAY AGAIN AND ITS SET
Feb 17, 2008 | Car Audio & Video
121 people viewed this question
 Grubhead
Grubhead
