Question about Raypak Pool & Spa
Incorrect temperature Temp is about 25 degrees higher than measured
    Top Expert:
  • Raypak Master
  • 6,465 Answers
Bad temp sensor
Posted on May 25, 2016
2 Suggested Answers
ditcher3
  • 44 Answers
SOURCE: display reads 68 degrees and pool is 84 degrees
Temperature Thermistor is bad
Posted on Jun 24, 2014
Need to know how to higher the temperature on a DF 830 double door deep freezer as its too cold
What are you saying is "too cold?" Normal freezer temp is 0 degrees F, how did you measure the temp?
Jun 05, 2016 | Freezers
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
I have a belling farmhouse range cooker but the gas mark numbers have faded so when the oven is switched on we don't know what temp it is on. Is there any way of fixing this?
Set the marker to the level as it is and measure the temperature with a thermometer. Now use a good marker and etch it on the metal body repeat it higher and lower with a gap of say 25 degrees. Have a marking on the knob set in place and now you have made a new calibration to the oven.
Use paint.sticker or anymedium to mark it properly .
Hope my advice helps.
Aug 28, 2010 | Ovens
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
The message center shows incorrect outdoor temperature. It reads about 25 degrees higher than outside temp.
I would suspect that the connection to the outside temperature sensor is not good or the sensor itself is bad. Check the connection and clean and reattach as necessary. Otherwise replace the sensor. I think they're pretty reasonably priced.
The outside air temperature sensor for a 2000 Windstar is located under the front bumber on the passengers side. It is clearly visible if you lay down and look through the lower two air openings in the plastic bumper. It is the only electrical device in that area and it is made of black plastic.
Sep 22, 2009 | 2000 Ford Windstar
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Pool & Spa Logo
49 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
