Question about Honda Garden
FR600 tiller shifter problem
FR600 w/maybe 40-50 hours on it started having hard-shifting prob; then could only get into 1st and 2nd. now it's stuck in 3rd, can't shift out. I'm ready to tear the shifter mechanism apart; I have the parts manual, but no trouble-shooting guide: any ideas or help?
    Sniper:
  • 60 Answers
Hi there .
Honda has a service bulletin for a improved gear shift lever for the serial #s betwen 1000001 and 2001784 .Check with your local dealer for this service bulletin or call Honda customer service to see if you are eligible for product improvement .
Hope this help.
Posted on Aug 29, 2009
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
2008 toyota Camry manual hard shifting from 1st to 2nd gear
With the engine off see if the shift between 1st to 2nd feel,s free if not it could be the cable check the clutch is disengageing all the way it should go into reverse without crunching,other then that it could be a synchro ring worn check that the gearbox has the right oil in it.
Dec 20, 2015 | 2008 Toyota Camry
Honda crf230f hard to shift into 2nd gear
Hi, Anonymous and the usual suspects are:
1. Clutch not adjusted properly.
6. A loose shift lever on shifter shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
crf 230 1st gear shifting problems
Shift Problem 2nd to First stuck in Neutral
Honda 2004 CRF250X Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CRF230F Owner Manual
Dec 26, 2013 | Honda CRF 230 F Motorcycles
I have a 91' ford f-150 that I pulled out of a parking lot and shifted from 1st to 2nd and instead of going into second it became stuck in fourth. then I proceeded to pulling the three screws out from...
if there has been no abuse or no chance somethind bent shifting rods under veh. check for loose or worn out shift rod connections,If internal trans shift drum problems your world just got more complacated
Aug 26, 2013 | Cars & Trucks
Is it ok to start off in 2nd gear and manually shift up to 3rd and then overdrive?
You can put the shifter in 2, 3, or overdrive. It will still start in first and shift up to whatever gear you have selected. Try it, you wont damage anythingl
Oct 22, 2012 | 1996 GMC Yukon
I have a 94 Jaguar xj6. the transmission light is on. it shifts hard in maybe 1st and 2nd gear. I've changed the transmission ecu, transmission relay, and fuses that have to do with the gearbox.
Change the xmission fluid and filter. If that doesnt fix it, it could be the solenids, the soleniod pack, what evey they call it on a Jag.
Sep 25, 2012 | 1994 Jaguar XJ6
03 Tiburon 5 speed stuck in 1st gear
Sounds like either the shift linkage is out of adjustment or damage to the shifting forks of the transmission.
Apr 03, 2012 | Transmission & Drivetrain for Hyundai...
Have you any ideas what i should check next?
Even though your shifter doesn't show 1st gear, your transmission will start out in 1st, then shift into 2nd at around 10-15mph. If you start out with shifter in 2nd, you should feel the gear change.
About all the average person can do with automatics is check the fluid, and possibly drop the pan and change filters. sometimes that helps with slipping or balky transmissions, but not always.
Good luck, Bill. Maybe somone else has some ideas?
Oct 28, 2011 | 1998 Saturn SL
Yzf r1 03 gear prob or?!
Sounds like bent shifting fork which is expensive. If you are not the 1st owner then you don't know how previous owner treated bike. Often sportbikes are rode hard and banged into 2nd gear which can eventually cause tranny problems like bent shifter fork. First look down by the shifter pedal and inspect that it is fastened securely to the shift rod coming out of the engine/trans case. There is a single bolt that holds the shift lever on a splined shaft and can come loose and cause problems.
If that is ok then find a local mechanic you trust....Good Luck !
May 08, 2009 | 2003 Yamaha YZF-R1
Garden Logo
372 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
