Question about Harman Kardon Audio Players & Recorders
Speakers harman kardon buzz
There is a constant buzz in my speakers when i use my harman kardon 2550 amplifier. It has this on all types of input both digital and analog. Also it doesn't matter which surround setting i put it.
  • 66 Answers
You have interference from something too close to your receiver. or too close to a speaker. don't stack all your devices together.
Posted on Apr 20, 2014
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 146 Answers
SOURCE: My harman/kardon speakers has static
The first thing is to make sure the speakers are bad. You can seitch them around from side to side if only one of them is bad, if the one speaker still has bad sound, thats your problem. You can also test the woofer of the speakers. Just push in on the woofer with your fingers to move the woofer in and out (with the stereo off). You should here nothing, if you do, the speaker is bad. If both speaker are bad, expecially if they went bad at the same time, the stereo is bad, expecially if you are getting the static with the stereo on and the volume all the way down. Going buy your problem I thing that your stereo is bad. It will need tobe repaired.
Posted on Mar 20, 2008
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
SOURCE: Harman Kardon DPR 2005 7.1 back speakers out
Upgraded unit at local electronic store for discount. wanted something with more power anyways. Thank You for
Posted on Oct 08, 2008
SOURCE: Denon AVR-2105
If the Cd is wired digitally, it will only play through the main zone, because the Denon cannot convert down to RCA to cater for the zone 2. If you plug RCAs from Cd to Denon, Main zone will STILL play from digital, and RCA connection will allow zone 2 to play Cd from RCA input....same with dvd, Satellite Blah blah... no stress, any nasty RCA will do if you want to try before you splash out on really costly cables...perhaps you can help me...want to run AVR 2105 with 2 speakers in zone 2, manual says cant do it - only ably to surround back or biamp...dont want either, dont have stereo yet to try it out...did you have any trouble with that?
Posted on Dec 03, 2008
It runs so hot why?
Possibly lack of ventilation or excessive volume through difficult speaker loads.
http://media.onecall.com/Image_Products/Harman%20Kardon/harman-kardon-hk990.pdf
See page 6.
IMPORTANT: When connecting two pairs of speakers, determine the impedance of each pair
by looking on the back of the speakers, in your owner's manual, or by contacting your dealer or manufacturer.
You can listen to two pairs of speakers at the same time ONLY if the impedance of EACH speaker is NOT LESS THAN 8 Ohms.
WARNING: Do not play sets of speakers simultaneously except as recommended above.
Amplifier may overheat.
Jul 09, 2011 | Harman Kardon Harman HK 990 Amplifier
I own my harman kardon 620 amplifier for about 8 years. Now the sound from the speakers comes on and off intermittently. I have connected and disconnected all the cables to the speakers but it still has...
The problem is in the audio circuitry, there are bad solder joints on the board that need to be addressed, from your description it is a intermittent issue with the sound. Since this a high end unit I recommend a top audio technician to work on your amplifier, and I suggest not using the system until it is repaired because the risk to the audio output parts getting damaged is high and they are pricey.
Jan 07, 2011 | Harman Kardon Harman HK 990 Amplifier
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Nov 22, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Getting buzzing sound from speaker but can here sound from them.
You could have an earth loop which causes a hum/buzzing sound.
Is your computer and powered speakers plugged into different mains?
Connecting amplifiers and speakers to different power sockets will create earth loop problems
This can be fixed by using a single power board connected to a single mains power socket, then connecting all the computer components and powered speakers into this one power board.
Oct 31, 2009 | Harman Kardon Harmon Kardon SoundStick II...
I need to replace an AC transformer for harman kardon PC speakers
If you still need it, I have the Hon-Kwang Plug in Class 2 Transformer Model A15-110.
Apr 05, 2009 | Harman Kardon HK206 Computer Speakers
Speakers Make a Very Loud Noise that Increases
speaker amplifier chip may leaky or damage
you are using improper sound driver
check driver status in your computer device manager or just typing dxdiag on run in start menu, check status of sound driver installation
Jan 15, 2008 | Harman Kardon HK19.5 Computer Speakers
No sound from speakers and display panel blinks all the time.
There could be a short somewhere and the stereo is protecting itself. Try connection to a different pair of speakers.
Nov 27, 2007 | Harman Kardon AVR 2550 Receiver
Harman kardon soundsticks II
use a clear silicone based sealant (similar to the type used for caulking and in fish tanks) I'm guessing you used CA or superglue, and thats what melted your plastic, you're using too much also most likely.
Sep 11, 2007 | Harman Kardon SoundSticks II Computer...
79 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
