Question about Dewalt Dc212 18 Volt Sds Plus Rotary Hammer Drill
How to grease - Dewalt Dc212 18 Volt Sds Plus Rotary Hammer Drill
What kind of grease do I Need to grease my babylock serger
no grease
only sewing machine oil applied at specific oiling points
Jul 29, 2016 | Sewing Machines
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
How do you do any maintenance (oiling or greasing - whichever is applicable) of rear wheel bearings in a 1987 jaguar xj6?
You don't. The bearing is greased for life. If the bearing is noisy it needs replacement.
FYI: Dismantling and greasing bearings does more harm than good due to the introduction of dirt, no matter how careful you are.
Modern greases are very sophisticated formulas of oil and soaps and last a long time.
Long gone are the days of white soap chassis grease that lasted 15,000 miles.
If the manufacture wanted it greased they would have installed a grease nipple in the housing.
However, over greasing a wheel bearing can sling grease onto nearby brakes and hoses.
The drive shaft CV joints are another thing however and you will find grease nipples in each joint behind the splash sleeves.
Jan 14, 2011 | 1987 Jaguar XJ6
Lot of grease accumilating on front driverside lower ball joint. Possibly from front axel???? Is this a output seal and grease coming from there down axel??
take a good hard look at the front cv-axle there is a rubber boot that has grease in it if its cracked you will have grease leaking from it more common the grease will end up on the inside of the rim and wheel well. if that boot is not cracked then the ball joint was filled with to much grease and the old grease was forced out most of the time it tears the rubber boot that protects and keeps the grease in, now you can wipe off the grease and it should be fine for a few years or so.
Dec 08, 2010 | 1999 Dodge Durango
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
1991 Toyota 4runner. would like to know how many grease nipples there are and where to find them. Thanks.
most cars these days have pre greased joints which do not require greasing, you just replace the part when it wears out, not a good idea but thats how it is.
Oct 04, 2010 | Toyota 4Runner Cars & Trucks
AFTER GREASING BOTH UPPER BALL JOINTS ON 2006 GMC 2500--GREASE SPITS BACK OUT--INITIAL LOOKED TO BE OLD GREASE, I AFTER A COUPLE DAYS WENT TO REGREASE AND NOW THE NEW GREASE SHOOTS BACK OUT.
you don't want to over grease 2or 3 pumps should be good at every oil change but if it isn't taking grease in the zerk a Little tap on top may fix it or you should unscrew it and replace with new
Mar 12, 2010 | 2006 GMC Sierra
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
Dewalt Dc212 18 Volt Sds Plus Rotary Hammer Drill Logo
44 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
