Question about RCA F27664 27" TV
Tv has picture but no sound !
I have a 27'' tv model # F27664, it has picture but no sound. Before the sound went out it had a buzzing sound like when you put it on a channel with no picture but now it does'nt have the buzzing sound either. appreciate your help. Thanks!
  • RCA Master
  • 3,866 Answers
Tihs would be do to a faulty flyback , A fly back is a circuit board that is on the back of the tube this being replaced will have much better results.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 19, 2009
After about 30 minutes of good sound and picture the screen goes fuzzy but the sound is still good
The tuner grounds on the main board need re solder, you will have to remove the tin covers on the tuner to get to some of the tuner ground's, this is a common problem for this set.
Dec 10, 2010 | RCA F27664 27" TV
TV WENT BLACK WITH BUZZING/SOUND
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
How to unlock a tv (Nutec model)
My tv has the red padlock problem please help thanks Ian
Sep 15, 2008 | RCA F27664 27" TV
No picture
unfortunately, your TV's tube has burned out. the replacement for a tube will probably cost close to the TV's price. At this point, your best option is to get a new TV.
Aug 29, 2008 | RCA F27664 27" TV
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Philips Magnavox 27" TV - no picture and buzzing sound
Are you using the video input? Do you get on screen display? If so you probably have the video (yellow) wire connected to one of the audio inputs.
Feb 08, 2007 | Philips Magnavox SC3127N 27" TV
TV Clicks on but does not start
sound like you have a bad capacitor in the horizontal deflection circuit check c14406 & c14402. each part is about $10.00. + you local shop rate. good luck.
Jan 30, 2007 | RCA F27664 27" TV
Picture, but No Sound
I doubt if it has fuses as most sets have what are called fusable resistors and these as fuse hardly ever go bad for no reason. these devices are there to protect the rest of the set incase of a short and to stop it from blowing up or burning. Fuses or fuseable resistor go our because of a short circuit. In your case the sound output IC or the capacitor assciated With it. Good luck
May 28, 2006 | Apex Digital AT2702 27" TV
RCA F27664 27" TV Logo
303 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
