Question about Toshiba Televison & Video
Toshiba DVD UJ8E2
Mechanism
Hi my Toshiba DVR20 combo plays a vhs tape for 5 seconds then turns self off any advice please
Tape transport mechanism fault. Contact any service technician. Tape do not run properly. Might be the fault of some belt/s or loading wheel.
google.com/+GopakumarGopalan
Jun 29, 2015 | Toshiba DVR20KB DVD Recorder
I accidentally loaded 2 dvd's in my Toshiba sd-v392 player and can't get them out.
Hi anne,
you have to remove the top cover,
sometimes you need to remove one or two extra screw of the loading tray mechanism,
go ahed.
it is not hard to do if you have philips screw driver.
if more asist please ask.
regards,
nuwan
Jan 13, 2014 | Toshiba SD-V392 DVD Player/VCR
Dvd keeps ejecting without playing from toshiba tv/dvd combo
It is a mechanical fault to its DVD loading mechanism. you have to take the mechanism out from the combo, to repair it. If you wish to get more details, and guidelines, check this link. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba Televison & Video
How can I unstick closed drawer on Toshiba SD-3900 DVD player?
see this steps and fix it. God bless you
Possible causes:
  1. Worn, stretched, oily, flabby, belt.
  2. Dirty mechanism or gummed up lubrication.
  3. Stripped gear or other mechanical damage.
  4. Defective motor or bad connections to motor.
  5. Bad drawer/eject button.
  6. Missing/bad voltages from power supply.
  7. Defective microcontroller or other logic.
  8. Dealer antitheft lock enabled.
Oct 15, 2012 | Toshiba SD-3900 DVD Player
My tv combo toshiba m md-20f52 dont work dvd
Hello
Check the laser pickup unit in the DVD player. You have to open the TV, and take out the DVD mechanism out from it to follow. If the set do not read and play any disc, replace the laser pickup unit with same type and number.
A semi-skilled work indeed. Have to disassemble and reassemble the DVd mechanism. Be care.
Feb 29, 2012 | Televison & Video
DVD w ill not eject from my Toshiba DVD player...Screen says open but the door never does
You will have to change the loading tray drive belt. For which you have to remove the top cover and then unscrew 4 screws that hold the disc mechanism and turn it upside down.You will see a small belt on a pulley which has to be replaced. Do all this only if you have access to replacement belt. In some players if you look at the bottom under the drive mechanism you will find a ****. Insert a thin screwdriver and push a plastic lever in the direction indicated with an arrow. The loading tray will eject the disc. Only some models have this feature. You have not mentioned the model # of your player.
Aug 08, 2011 | Toshiba DVD Recorder
I have a Toshiba TV/DVD Combination (26HLV66) and there is a dvd inserted that will not eject. Any suggestions?
There might be a mechanical problem with your dvd player but if you want to eject the dvd that is inside the player, try this:
Look for a small hole in front of the player, usually above the cd tray. Get a a small piece of wire or a paper clip that will fit into the hole. Push the wire of paper clip intot he hole until the cd tray opens and then you can remove the cd/dvd.
Sep 08, 2010 | Toshiba Televison & Video
The open/close door will not open
the problem of this is that the rubber attached to the motor of the mechanism may be slack or cut , replace with the same size and if otherwise replace the whole of the mechanism..
Good luck...
Jun 01, 2010 | Toshiba SD-3950 DVD Player
Toshiba Cd drive won't close
There must be a small part locking mechanism that broke or lose thread inside your dvd drive. gently open it and you will see it.
Apr 20, 2008 | Toshiba Satellite A70 Notebook
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
