Question about Sony Electronics - Others
Driver sony memory card d33021 - Sony Electronics - Others
I have a sony D33021 flash drive and its unable to format.what should I do ? please help.
You can fix it with this program :MiniTool Partition Wizard Professional Edition
download it from here
http://www.multiupload.nl/8AD2XR33H3
Install the software and open it and you will be asked Put this serial number
A8C5U5YAUY5UK43YK4MYKSCUVXKSU454
When the update asks choose not
Then
go to the flash and press the right button and format and select the Apply and wait will formate then will you have a flash
Mar 12, 2012 | Sony Electronics - Others
I have a Polaroid a310 I recently bought a card for it it is a Sony 4GB. I put it in and started taking pics, they went to the internal memory. Then I went to the menu to copy to card it said no files...
Hello!
I have had the same problems with Sony memory cards before. I found out that most Sony memory cards work only with Sony Cameras. This is because most drivers used to manage these memories are licensed by Sony.
Try getting another kind of memory card for your camera. I recommend Kingston memories.
Good Luck!
May 04, 2011 | Polaroid a310 Digital Camera
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Can not read the MSPro Duo Card in my newly formatted Sony VAIO VGN-CR21S I lost the webcam driver too while formatting the the HDD
go to sony.com and under support list your model number and select drivers. then look for a chipset driver for the memory stick and a webcam driver for the cam . download each and then run each driver. heres the link to enter the required info to locate the drivers you seek.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
Nov 29, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
My laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
Mar 14, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Dell laptop computer don't open mobile memory card
my 1GB gateway meory stick cant not show the items on it.
Mar 21, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick card reader won't read
have you installed the driver for the 5-in-1 card reader?
check hp for your model.
Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Electronics - Others Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
