Paper cutter error
Sams4s sps520 paper cutter error
I need a schematic for a Katsuda JMC4s Paper Cutter from Japan?
Hi
I had JMC III KATSUDA (SH290HOP-N) paper cutter and memory shown ERROR 2. Memory did not work. Please let me know if you have any idea to fix it. My email is
leonardprint@gmail.com
Thank you
Dec 29, 2014 | Office Equipment & Supplies
A17-209 error message
A-17-209 is a cutter error meaning the cutter is not at home position when master material is in place. The cutter can be manually slide towards front of machine or another way is to rerolled master paper back on to its roll and close the clamp. This will cause the cutter, if operational, to re-home itself correctly. There are test codes to operate cutter to check it (480).
Nov 07, 2013 | Riso RZ220 Duplicator
Paper jam sign appear all the time
If you get this error check for paper jam and see if the paper cutter is seated right and is not defective. You can try cleaning the cutter and lubricating it, even then issue not resolved replace the gear train.
Dec 10, 2010 | Brother Office Equipment & Supplies
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Xerox 6204 error 071-103
The cutter assy has a disk with hole in it to tell the circuit board how fast it is turning and where it is in respect to the home position. It may be that this disk or the sensor that looks through it has a lot of paper dust on it and not able to read correctly. It may me the the cutter itself is sticking and needs a little cleaning and oiling.
Jan 23, 2008 | Office Equipment & Supplies
Cbm 1000 thermal printer
replace cutter assy. Part # Acc-230kit or send in for service.
Agson - 856-751-9048
Dec 02, 2007 | Citizen CBM 1000 thermal Printer
Error message
Problem: The Printer does not detect the home position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or there has been an impact on the lower side of the printer causing a bend in the metal that holds the home switch. This switch will trigger a sensor telling the printer that the cutter has reached the home position(right side)
Solution:Remove the paper scrap or Remove the door panel and check for damage on the right side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the right side.
Nov 30, 2007 | Sony UP DR100 Thermal Photo Printer
Cut err
Paper Cutter Error - Guiliteen isnt sliding across the  rail it runs on properly  try lubing rail that cutter runs on with a LITTLE light oil , near front paper exit area
Oct 19, 2007 | Citizen CLP-7201E Thermal Label Printer
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
