Question about Singer Sewing Machines
Bobbin thread puckers - Singer Sewing Machines
  • Singer Master
  • 1,388 Answers
  • 323 Answers
SOURCE: thread
you need to do a tension assembly test.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air. The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Posted on Nov 07, 2008
SewExpress
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
lintalks71
  • 7 Answers
SOURCE: I have a viking designer I and I am trying to embroidery lettering. No matter what I try, it puckers. It looks like the bobbin tension is too tight because I use red thread on top and white on the bot
It sounds like a stabilizer prob. Try some better stabilibers maybe heavier. It may just need the be adjusted by a sewing technician at your local dealer. You can often take these in and have them hooped up and tested right there on the counter. I can do this at my store here in Portland, OR. They usually like them to run well or they get a bad rap. Just try better bobbin thread like anything but YLI. Try a different needle possibly. Or call Gary at 503-254-7317 and ask him what needle to use and what stabilizer and say Lin asked him to assist you. Tell him you are my friend.
Posted on Jun 19, 2009
  • 1564 Answers
SOURCE: I have recently bought Singer Quantum 9940 and I
1. Make sure your needle is correct for the fabric. Go buy some good needles in several sizes. You'll need a 90 for jeans, rounded points for fine fabrics... get a few sizes. Your manual should provided you with clues to the right needle for the fabrics. (BTW... there really is no such thing as a Universal Needle... toss it.)
2. Re-read your manual and carefully follow the instructions on threading the bobbin and the upper thread...
3. Check your tension on the upper thread... it is too loose for the application. The tension on the bottom thread is handled by a spring on your bobbin case or race. If you do not have that threaded properly you'll have problems. Same with the direction the bobbin turns... have in it backwards... problems.
Barring all these things... It might be time for a qualified Singer repair person to look at it. Sadly Singer has seriously lowered it's standards in the last 20 years.
Posted on Feb 06, 2011
  • 6 Answers
SOURCE: Machine not taking up bobbin
You may need to take q-tips and clean the lint out of all the places you can. Take the bobbin out and clean there too. Take the plate off and clean the feeder. Make sure you are using the same thread on the bobbin as you are using on the top. Rethread the top making sure it is threaded correctly. Change the needle...making sure it is the correct one. I have found that you cannot use Singer needles or white label needles. The only needles I have been able to use with Brother machines are Schnetz as the other needles are too long and cause some of the problems you are having + they break as the hit the bobbin. Hope this helps you.
Posted on May 02, 2011
Need help with tension as thr stiches are puckering.
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
How to Prevent Your Sewing Machine from Puckering Fabric Howcast
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwjcuq2nkIPMAhXlxIMKHVgUAqUQFgg1MAU&url=http%3A%2F%2Fwww.amannusa.com%2Fpdf%2Fnahtkraeuslen_gb.pdf&usg=AFQjCNE-YAZ5WB1V7bFGptxZojumhoodMQ&cad=rja
Stitching is puckering on lightweight fabric SEWING IN GENERAL
All About Needles
Apr 10, 2016 | Sewing Machines
Bobbin keeps jumping out
Hi Anonymous, The link below is a YouTube video showing how to thread a bobbin, The sewing machine is a Singer...Also there's videos down the right side of the link that may help..... CHEERS..
Sewing Basics 1 How to thread your machine
Mar 05, 2016 | Sewing Machines
Bobbin spinning up off spool when winding
Slow down the speed. Bobbins should not be wound at a high speed because it will sometimes cause the bobbin or thread spool to rise (and even jump off the machine!). Also the thread tends to be stretched when wound onto the bobbin. Then when sewing, the thread relaxes and may cause the fabric to pucker.
How do i stop geting puckering when sewing
A lot depends upon what you're sewing on, thread, needle, etc. But here are some basics for this problem:
1. Clean your machine! The most common cause of many sewing problems is smutz caught in the bobbin area or tensioning disks.
2. Change your needle and be sure it's the right weight and type for what you're doing. Using a heavyweight needle on lightweight fabric or a 'sharps' needle on knits or an old needle are common causes of puckering.
3. Make sure the thread you're using is appropriate for the fabric and needle. Using light thread on heavy fabric or vice versa can cause puckering as well.
4. Check your tensioning, both upper and bobbin.
5. Take it in and have the timing checked.
Apr 15, 2015 | Janome D'cor Excel 5018
What to do if sewing machine is puckering?
Depends on why the seam is puckering. Read this: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf
Offhand, it sounds like you need to reset the top tension properly.
http://quilting.about.com/od/piecingtechniques/a/How-to-Adjust-Sewing-Machine-Tension.htm
The top two photos here are the upper and underside of a single ply of muslin sewn with a balanced tension. The blue thread is on top, red in the bobbin: http://www.picturetrail.com/sfx/album/view/22521551 -- that will give you something to shoot for.
Jun 12, 2014 | Kenmore 19233 Computerized Sewing Machine
Waht is the best thread to minimise puckering
Depends on why the machine is puckering. Take a look at: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf Usually, if it is a thread puckering problem, winding the bobbin thread more slowly, using a less elastic thread like a cotton, and reducing machine tensions will help.
Apr 28, 2014 | Janome Sewing Machines
Depends on the reason for the puckering. Do you have insufficient presser foot pressure? Are you having structural jamming problems (stitches too short/thread too thick)? Is the thread stretched during sewing and then relaxing (in which case you've probably got a tension problem)? Did you wind the bobbin too quickly? Are the plies moving relative to each other? Are the fabric plies cut on the same grain? Is the fabric stable, or is it something like a stretch woven? See: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf http://www.amefird.com/wp-content/uploads/2010/01/Sewing-Stretch-Woven-Fabrics-2-5-10.pdf
Thread is puckering at back and then breaking
try changing the needle
and try adjusting the top thread tension
also make sure the top thread is not caught anywhere
make sure the bobbin is turned the correct way in the bobbin case
Jan 18, 2014 | Bernina Sewing Machines
My seams are puckering. I have a Brother sewing machine. What am I doing wrong?
Puckered seams are usually caused by incorrect tension. But first check to make sure your bobbin is inserted correctly and that there is a good tight wind on the bobbin itself. Then, check the tension disks in the upper threading and make sure there is no stray thread lodged in there. Next, check the upper threading to be sure you have the thread going correctly through each of the thread guides and between the tension disks/plates. Finally, check the tension. Generally it should be on 3 but each machine has different symbols for the tension. My Brother product uses a 3 tension. I've been sewing for over 50 years and I still occasionally have pucker problems. It's usually because there's a small stray piece of thread in between the tension disks. I hope this helps you. If it does, please come back to Fixya and rate my information! Thanks.
Aug 02, 2011 | Sewing Machines
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Sewing Machines Logo
12 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
