Question about Kenmore 75944 Gas Dryer
Kenmore gas dryer model 110.72924100 will tumble but not heat up.
Gas supply is OK. I have already replaced the hot surface ignitor, which was old and reading 70 ohms. The gas solenoids both check out at 1,300 ohms. The overheating sensor is closed at room temperature, and open when heat is applied, which I think is correct. When I set a heat level and press the start button, however, the unit tumbles, but the ignitor does not heat up, and the gas does not come on. This unit has a couple of sensors on the exhaust duct inside the dryer. Would those stop the ignitor from working if they were bad?
  • 2 more comments
  • markbeu Jun 19, 2009
    Fix Ya's first response appears not to have taken into account what I said in my post. When I start the dryer, the ignitor does not come on at all.
    I had seen the previous expert's comments before, and they do not address my specific problem. The ignitor in my dryer does not come on or glow at all, not even for a few seconds. All the components,including the ignitor, the solenoids, and the flame and overheating sensors, seem to check out, but nothing happens when I start the dryer except that the barrel turns.
    There is no airflow problem. All ducts in the unit are clear, and the exit duct is only 18 inches long. I checked the two sensors that are on the duct carrying air away from the dryer barrel. One had four leads, two in the center, and two at the outside. The outside leads read 0 ohms, and the two center leads had about 6,000 ohms across them. The sensor right next to that one only had two leads, and they were open - the only sensor that read as open in the whole unit.
  • markbeu Jun 20, 2009
    sethvel1 is correct, but I had figured this out on my own before seeing his post. The thermal fuse on the discharge side had blown. When I shorted its leads (a test I learned elsewhere) the unit began to work properly. I have already purchased the replacement part.
  • 334 Answers
Hey there, any sensor on the discharge air side of your drier are going to be safeties, meaning if they are open then they are tripped, you can cut the leads ( long enough to be able to re connect to the switch) and then wire nut them together. Sounds to me like either you have a problem somewhere from the temp control through the safeties or if that's all good and you are still not trying to power your ignitor then it is probably your ignition module. The ignition module reads the amp draw throught the ignitor to know when its hot. Also, I know you ohmed it out but visualy check for cracks anywhere and do not touch it with your fingers. Let me know what you find out.
set
Posted on Jun 20, 2009
  • 242 Answers
Yes they are safety's that will shutdown the unit , there should be 1 on the duct and 1 on the flame tube , they should both read low ohms. if you have an exhaust problem with the unit the airflow will decrease causing the flame to out of line.
check these out and let me know how it goes.
Phil
Posted on Jun 19, 2009
  • 1,800 Answers
Hello.
Welcome To Fixya
A Gas Dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and in dryers that use a glow type of ignitor, a flame sensor. If the flame sensor fails, the ignitor may not go off and the gas flow will not start.
The easiest way to diagnose the flame sensor is to observe the burner operation. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
For testing purposes, the sensor should show continuity at room temperature and no continuity when it is heated by the ignitor.
My GE gas Dryer does not iginite and get hot. It turns or tumbles but does not get hot. Checked gas line everything ok with gas line. please provde step by step instraiuctions to replace the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 18, 2011 | Dryers
I have a Kenmore 600 gas dryer and every once in a while it does blow hot air. It tumbles and seems OK other than that.
heatman101 ' '; ';
Aug 12, 2011 | Dryers
Kenmore Gas Dryer 11072212101 won't heat. we
heatman101.,/
Jun 30, 2011 | Kenmore 73102 Gas Dryer
My kenmore is 21 years old it is still tumbling but has lost its heat to dry
heatman101';
May 24, 2011 | Kenmore Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Dryer starts hot surface ignitor comes on gas valve opens i get a flame 5 mins flame shuts off hot surface ignitor repeats and tries to ignite no flame after unit is off for 20 mins to 30 mins off unit...
heatman101
Sep 17, 2010 | Kenmore 77632 Gas Dryer
Dryer tumbles but no heat
I believe this unit has a hot-surface ignitor, and they work great, but do go bad eventually. The easy way to tell is to visibly see if the ignitor is operating during startup... can you get to it?
The hot-surface ignitor is easy to replace- (be careful not to touch it with fingers - like with halogen bulbs)
Dec 15, 2009 | Dryers
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Gas dryer starts to tumble but it doesn't get hot and dry clothes
It's either a ignitor or the gas valve. Is this something that you could work on?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 02, 2009 | Kenmore 63942 Dryer
Gas Dryer won't Dry
Luke Check the flame sensor
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2008 | Kenmore 64952 Electric Dryer
Kenmore 75944 Gas Dryer Logo
173 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
